DR J's Airwolf 220 heads.
Author Topic: DR J's Airwolf 220 heads.  (Read 5357 times)
Offline 73restomod
« on: December 27, 2012 - 10:42:28 PM »
Non- offset rocker SB Mopar aluminium heads, over 320 cfm out of the box. Check out the new Engine Masters for more info.
Sent from my DROID RAZR using Tapatalk 2
Offline cudabob496
Re: DR J's Airwolf 220 heads.
« Reply #1 on: December 28, 2012 - 04:23:34 AM »
my engine use to just quit. turned out the electronic ignition orange box was too close to the headers, and
was overheating.  when it cooled off, would then work fine.  Moved it to under that dash.
2011 Kawasaki Z1000
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #2 on: December 28, 2012 - 04:29:11 PM »
What?
Bob, I think you posted in the wrong thread.
These heads look like they would work really well.
Are you gonna use these?
Offline TinCuda
    • 'Cuda
« Reply #3 on: December 28, 2012 - 05:06:08 PM »
My cat's breath smells like tuna and my knee hurts...
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Offline 73restomod
« Reply #4 on: December 29, 2012 - 02:07:57 PM »
Squirrels, they're in the trees, they're everywhere man....
Offline 73restomod
« Reply #5 on: December 29, 2012 - 02:11:14 PM »
No, I won't be using them, :'( but I figure I'd list them here. I will post the flow chart shortly.
Offline 73restomod
« Reply #6 on: December 29, 2012 - 02:18:27 PM »
AIRWOLF 220 Small Block Mopar
The new AIRWOLF 220 Small Block Mopar is one of the best performing out of the box non offset rocker cylinder head available today. The AIRWOLF 220 is a direct bolt on and takes all standard LA hardware.
AIRWOLF 220 small block mopar Technical Details
Material: A356  Aluminum
Valve Angle: STD LA mopar
Bore Spacing: Standard
Valve Spacing: STD
Intake Port Volume: 220cc
Combustion Chamber: 64-68cc
Exhaust Valve Diameter: 1.600 11/32 dia
Intake Valve Diameter: 2.08 11/32 dai
Spark Plugs: Angled .750 Reach, Gasketed
Valve Guides: Bronze Alloy
Spring Pocket: 1.625 OD Maximum
Valve Seats: Ductile Steel
Intake Gaskets: FELPRO 1213
AIRWOLF 220 SBM
 2.08 intake 1.60 exhaust 45 ° seats
 2.48 CSA @ pinch
Intake Flow numbers @ 28” test @ Reher Morrison
.100 72 cfm
 .200 144 cfm
 .300 219 cfm
 .400 273 cfm
 .500 301 cfm
 .600 312 cfm
 .700 316 cfm
 .800 319 cfm
 .900 321 cfm
 1.00 326 cfm
Here's a link-  http://www.j-performance.com/index.php?option=com_content&task=view&id=59
Offline 74challenger03
« Reply #7 on: December 29, 2012 - 06:15:03 PM »
Thanks for the laugh guys. :roflsmiley:
« Reply #8 on: December 29, 2012 - 09:04:26 PM »
I had one too but it was Blue
 Thanks for the info BTW
Offline 73restomod
« Reply #9 on: January 16, 2013 - 06:55:16 PM »
My final thoughts on this, if they can get that out of a standard port head on a small block, what could they get out of a big block.......
