Author Topic: master cylinder question  (Read 713 times)
Offline barryv
« on: December 30, 2012 - 10:16:58 AM »
hi, i have a 1972 barracuda. is there any advantage by using the more modern aluminim style master cylinder over the original style.thanks
Offline 4 speed fish
Re: master cylinder question
« Reply #1 on: December 30, 2012 - 12:21:45 PM »
I would use a Oem replacement master cylinder.Sometimes when you use a different part you can open up a can of worms.The pressure and bore size could be different so your pedal feel and brakes locking up could be a problem.
Offline 72cudamaan
« Reply #2 on: December 30, 2012 - 08:16:15 PM »
Just make sure you do your homework. Match the bore size. You may have to fiddle with the
pushrod adjustment.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline barryv
« Reply #3 on: January 03, 2013 - 10:24:44 AM »
thanks for replies
