Reverse Light Harness - 4-Speed (FOUND)
Author Topic: Reverse Light Harness - 4-Speed (FOUND)  (Read 6167 times)
Offline Jamiez
  • Retro
Re: Reverse Light Harness - 4-Speed (FOUND)
« Reply #15 on: January 02, 2013 - 09:18:43 PM »
If the one you have posted pics here is for sale I'll take it.
I guess the small grey connector comes thru the firewall and goes to the reverse light. Now which of the smaller fuseblock connectors does it connect to, left or right?
Yeah the manual one is for sale.  Just PM me about it.
Judging by Topcat's picture, the wire that goes to the light has the grommet and passes through the firewall.  The entire harness I have goes outside the firewall.  I believe it connects to the lower passenger side of the fuse block.
« Reply #16 on: January 02, 2013 - 09:26:49 PM »
Correct!
Picture from Alan, a new member here.
Hole straight down from the throttle cable. 1"
1970 had a different location.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #17 on: January 02, 2013 - 10:45:07 PM »
Gotcha, I have the grommet so I'll take a look at it.
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
« Reply #18 on: January 08, 2013 - 03:25:41 PM »
HP_Cuda .... just to clarify.   I just purchased a $16 wiring harness with the socket that runs from the Light housing (Chrome bezel and red lense) in the dash to the other harness that connects to the transmission.   It is two different harnesses.   I originally bought the transmission harness first .... then reallized that my light bulb harness was missing the connector, etc ....   hence I then went back to Evans and bought the other piece of the puzzle.   You also need the $7 clips that go on the side of the A-833 to hold the harness in place.  They are on ebay.
Hope that clarifies my side of the equation?
CHAPS
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
Offline HP_Cuda
  • Mopar or No Car!
« Reply #19 on: January 08, 2013 - 03:38:07 PM »
Yep got that part while talking with a buddy but thanks for the tip on the clips.
B
CHAPS
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #20 on: March 08, 2013 - 05:30:17 PM »
B
Does anyone know where to get these harness clips?  I looked on ebay, but no clips came up when I did a search for A-833.  Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline 1BADFISH™
« Reply #21 on: March 08, 2013 - 05:45:15 PM »
My car was originally a 3spd manual, now its a 4spd. I have the light bezel (chrome and orange lense) for the dash, but I need the bulb and wire as well. Anyone know what I would need? I'm confused after reading through this thread lol.   :clueless:
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
« Reply #22 on: March 08, 2013 - 09:20:19 PM »
Even shows where they go.
http://www.ebay.com/itm/380562069926?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
