Author Topic: Dutchman panel seams  (Read 1914 times)
Offline GCC
« on: December 30, 2012 - 11:51:12 AM »
How were these seams finished from the factory?  Were theses seams finished the same for hardtops and convertibles?  I have a 70 Barracuda convertible, the dutchman panel is original, but the quarter panels have been replaced.  There is evidence of lead in these seams.  Were the seams leaded/finished flush with the surrounding metal to completely hide them?  Any photos would be great!   :cheers:
Offline jimynick
Re: Dutchman panel seams
« Reply #1 on: December 30, 2012 - 02:16:28 PM »
On my 74 coupe, the upr. trunk panel seams to the 1/4's were spot welded together and had a seam sealer in them. No solder  :2cents:
Offline 67vertman
  • Member since 9-23-2005
« Reply #2 on: December 30, 2012 - 02:44:10 PM »
You are talking about this panel right?
Mine was welded in with no signs of lead when I replaced it.  The factory look has the seams to the trunk like shown.
Offline 72cudamaan
« Reply #3 on: December 30, 2012 - 03:08:22 PM »
My 72 has the seams as well. No indication of lead there.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline larry4406
« Reply #4 on: December 30, 2012 - 03:55:09 PM »
On a vert the seam is not visible.  Not sure how the factory did it (I assume lead given the chunk I found in the trunk hinge area).  Hardtops the seam is exposed like in the prior picture.
Offline steven
« Reply #5 on: May 20, 2013 - 08:54:33 AM »
What did you end up with as to a "Final Solution" ? I will have to solve the same thing on my '71 B-cuda 'vert. I know there was lead. What I don't know is how much. Were the seams invisible when done or just a little shallower than on a hardtop ?  Should have taken more photos but didn't know the car would be apart for a hundred years when I started.
