Author Topic: Door glass help where do these brackets go on the door ?  (Read 1654 times)
Offline AZDAN
« on: December 31, 2012 - 03:03:15 PM »
Can anyone tell me where these 2 brackets bolt on the door. In the pictures I took when I disassembled I did not take any of where these mounted at. I figured out where the felt ones go but not these 2 brackets.
Offline HP_Cuda
  • Mopar or No Car!
Re: Door glass help where do these brackets go on the door ?
« Reply #1 on: December 31, 2012 - 04:25:44 PM »
I believe they are near the top to guide the window.
Do a search I think someone did a window assembly thread on here.
Offline Fern
« Reply #2 on: December 31, 2012 - 07:58:21 PM »
They look like the inside window pieces that hold the glass, but they have no felts.
My doors are still open and I will look tomorrow to see if  I can find where those go.
I'll take some picts
What car and year is it from.
Offline BIGSHCLUNK
« Reply #3 on: December 31, 2012 - 09:59:32 PM »
As I recall those look like "rollup" stops. dont know what ma calls them tho  :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline cuda joy
« Reply #4 on: January 01, 2013 - 11:28:44 AM »
Hi there and happy new year,
I do reconize those brackets because door parts get frustrating ... they go as upper glass door bump stops to the front side of door. they mount just like
felt covered ones but are thinner for glass clearance. they mount on the inner door top area just like rears do.   Important fact as you adjust glass make sure they dont go out to far or they can scratch glass on inner surface. hope that helps I have done a lot of doors recently and have more to come. :working: :cheers:
Offline BIGSHCLUNK
« Reply #5 on: January 01, 2013 - 12:03:28 PM »
Well put!  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #6 on: January 01, 2013 - 02:03:35 PM »
Believe this is where they go.
Offline Fern
« Reply #7 on: January 01, 2013 - 03:54:58 PM »
The up stops do not have a bolt on it. Just a slot where a bolt goes through into the outside panel.
Looks more like inside felt clips without the felt.
Good luck.
Offline AZDAN
« Reply #8 on: January 03, 2013 - 10:40:41 PM »
Thanks Fern those pictures are what I needed especially the last one.
Offline Travis72
« Reply #9 on: January 09, 2013 - 12:36:04 AM »
I think it depends on the year.  What year is your Cuda AZDAN?  Your upstops look exactly like the ones in my 72.  In which case they go on the inside panel just under the fuzzy/felt bracket.  See this picture (for the rear one).  The slot above it is for the fuzzy/felt bracket.
For the front one just look at where your plastic upstop is when the window is up and it will be easy to tell where they attach to the inside panel.
I guess an easy way to tell is what way do you have your plastic upstops installed in the glass?  Pointing towards the outside of the car or towards the inside of the car?
Travis
72 Cuda
