Author Topic: LA to Magnum head Conversion water pump to intake hose?  (Read 813 times)
Offline moparmaster
« on: January 02, 2013 - 07:06:02 PM »
What the heck?  The molded hose from an LA water pump will not correctly route to the Edelbrock Magnum intake water inlet.  Does anybody make a different hose for this?  I tried to cut some regular hose and curve it but there is no way that won't end up leaking.
Re: LA to Magnum head Conversion water pump to intake hose?
« Reply #1 on: January 02, 2013 - 10:24:41 PM »
Can you post a picture?
Offline moparmaster
« Reply #2 on: January 06, 2013 - 02:29:51 PM »
I tried to attach this before but it didn't take.  I think I might just use two molded "stock" hoses and Frankenstein them together with a double male fitting to make it work.  The bends are just too tight to do it any other way as far as I know.  As it sits, you can almost put a finger in the intake end of the hose!
« Reply #3 on: January 07, 2013 - 07:45:02 AM »
I wonder if a molded hose for a BB Buick or SB  Ford would work? Or what about an
90 deg. elbow?
Offline moparmaster
« Reply #4 on: January 07, 2013 - 01:36:03 PM »
The hose out of the water neck comes out at a slight angle and not in line with the intake fitting.  I could try several different ones but I'll have to do some research on the other types first.  It's those little details that get you caught up!
Offline 73restomod
« Reply #5 on: January 07, 2013 - 01:44:20 PM »
I had to do this once, I cut down the factory LA hose and hooked it up. Has a very small kink on the driver's side. Never had an over heating issue, or even a leak. Oh, on a side note you will have to use a magnum specific thermostat on that intake, as the opening isn't large enough to accommodate a high flow LA style thermostat.
Sent from my DROID RAZR using Tapatalk 2
« Last Edit: January 07, 2013 - 01:49:42 PM by 73restomod »
« Reply #6 on: January 07, 2013 - 04:51:17 PM »
What about a 90 deg. fitting on the intake and use these 2  connection to run your heater core  from?( if your running a heater core?) Then it would loop it back.
