Author Topic: Ignition  (Read 802 times)
Offline Dusty1
  • Revived
Ignition
« on: January 02, 2013 - 09:04:34 PM »
Pertronix second strike, coil, distributor, contol box. I'm having trouble getting it to fire right, the directions say I need the original ignition modual connected, but doesn't tell me how to wire it in. Anyone ever used this?
Garys 1972 BS
Re: Ignition
« Reply #1 on: January 03, 2013 - 05:40:52 AM »
is the power for the dist connected to 12v feed not the lower voltage feed at the coil + terminal ?
Offline Dusty1
  • Revived
Re: Ignition
« Reply #2 on: January 03, 2013 - 08:25:30 PM »
Yes it has power, it starts and runs, but only at low rpm's. The directions in one place say you need the primary ignition modual, in another place it doesn't mention it. I've got the stock ignition back on it now and it runs fine, but I have to figure this one out. It tells me nothing about how to integrate the original modual into this system. I thought it would be a stand alone system like MDS. Thanks
Garys 1972 BS
Offline cudabob496
Re: Ignition
« Reply #3 on: January 03, 2013 - 10:55:18 PM »
2011 Kawasaki Z1000
