Author Topic: K-Frame Issue??? update!  (Read 13203 times)
Offline CUDA JAS
  • vroooooom!
« on: January 04, 2013 - 10:02:52 AM »
SO, pulling apart the front suspension on my cuda, I think I found an issue with my K-frame.
Here are some pics of the pass side strut rod mounting home at the front of the frame.  Some of the pics are extreme close ups (sorry frame is still in the car)
From under the car
I sure looks like the hole is all screwed up.
Will this cause an issue with the front suspension?
Can I use this, or woudl I be better off replacign the K-frame.
Jason
« Last Edit: February 16, 2013 - 04:10:02 PM by CUDA JAS »
74 'cuda 360/727
Just call me a gearhead!
Re: K-Frame Issue???
« Reply #1 on: January 04, 2013 - 11:02:21 AM »
That's not good.
The strut rods hold the lower control arm in triangulation so there is a pretty large amount of thrust loading on this area during braking. You certianly woudl not want a bushing pushing through that area.
You could work on it some to avoid replacing the entire K, but it certainly would be easier to simply unbolt it and bolt in a another one if you could source one cheap enough. If you want to do repairs, you could have the area flattened out and oversize area welded up with an insert that has the correct sized holes.
I would also recommned doing a close inspection of the lower control arm mounting area to ensure that it is not egged out or cracked.
Offline anlauto
« Reply #2 on: January 04, 2013 - 11:16:36 AM »
Jason....SCRAP that K frame.....Trust me.
It's not that big of a deal now that you're that far along. You can simply support the motor and steering box from above, undo the motor mounts, K Frame bolts, steering box bolts and drop it out.
Offline ChallengerHK
« Reply #3 on: January 04, 2013 - 11:21:26 AM »
I wonder if that's related to your UCA issue.
- Han Solo, Star Wars
Offline CUDA JAS
  • vroooooom!
« Reply #4 on: January 04, 2013 - 12:26:12 PM »
Yep that is the way I am leaning...but I am worried about how to support the engine.
Looks liek I better start looking at the funny papers.
I am betting that is one of the reasons that car just never felt quite right.  :dunno:
Jason
« Last Edit: January 04, 2013 - 12:33:42 PM by CUDA JAS »
74 'cuda 360/727
Offline anlauto
« Reply #5 on: January 04, 2013 - 12:40:33 PM »
Supporting the engine is simple. Get a square pipe 2 X 2 , cut it to length so it will rest on the top of your inner fenders. Pad each end of the pipe and just place it across the engine bay. Rise the motor slightly and chain the motor to the pipe.
Offline jimynick
« Reply #6 on: January 04, 2013 - 06:28:26 PM »
What Alan said, but a 4x4 will work, too and it's cheaper. Och aye! If you need a hand, let me know. Ian
Offline anlauto
« Reply #7 on: January 04, 2013 - 06:42:04 PM »
Yep...several things with work....There is an actual tool for this that a lot of shops use when removing FWD transmissions. Maybe a local shop can spot you the correct tool ? Just have a new K Frame ready to go in, and it will be an afternoon job.
Offline CUDA JAS
  • vroooooom!
« Reply #8 on: January 04, 2013 - 07:08:20 PM »
Thanks guys.
My plan will be to have a new K-frame already to go before pulling out the old one.
Jason
74 'cuda 360/727
Offline anlauto
« Reply #9 on: January 04, 2013 - 07:46:04 PM »
If you are going to swap the K Frame...I would assemble it completely outside the car then put it back in place...but that's just me....I would also paint the K Frame a more manly colour like black  :poopoke:  :roflsmiley:
« Reply #10 on: January 04, 2013 - 07:53:19 PM »
I'd take the time to reweld up the replacement k frame and gusseted the steering box mounts too!
« Last Edit: January 05, 2013 - 09:50:29 AM by brads70 »
Offline wiging19
« Reply #11 on: January 05, 2013 - 03:31:01 AM »
I'd take the time to reweld up the replacement k frame and fussed the steering box mounts too!
This is a very good suggestion.  My steering box nuts were loose in the K frame and this made a big difference in how the car handled and felt.  The friends I have who have strengthen their K Frame with welds say it significantly improves the handling of their cars.
Offline CUDA JAS
  • vroooooom!
« Reply #12 on: January 05, 2013 - 07:34:21 AM »
Yep, that is my plan.  I spent a few hours yesterday looking into what others have done to reenforce K-frames.
Jason
74 'cuda 360/727
« Reply #13 on: January 05, 2013 - 09:55:09 AM »
Jason
Some good pictures here....
http://www.firmfeel.com/reinfkfram_e.htm
Offline drewcrane
« Reply #14 on: January 05, 2013 - 11:02:14 AM »
I made some plates ,and welded it up on the car, my Kframe cracked during my V.P. trip,I realize your is in the strut rod area ,but the same thing needs to be done in both LCA and strut rod area,
 and  I had to have the car towed from Vail the steering became so loose the UCA was binding up pretty nasty
« Last Edit: January 05, 2013 - 04:11:00 PM by drewcrane »
