Author Topic: What would I really lose?  (Read 1290 times)
Offline onebadfish
« on: January 04, 2013 - 10:22:00 PM »
Been looking at the cuda.....(can't do much else with a foot of snow on the ground) 440-6 pack, 4 speed, 906 heads, standard mopar bump stick (forget the part number)..nothing radical..runs great. Dynoed at 410hp at the flywheel only have 3600 miles since full rebuild...but I want more.
Stroker 512-solid flat tappet that pulls to 6200, headers...headers...well, when I check out the engine bay I can see where a set of headers would be a PITA to install (my last toy was a little red express) and maintain with torsion bars, starter and clutch linkage in the way! So hence my question - What do you lose by keeping the orignal exhaust manifolds? I really like the way the engine bay looks stock....can I build an iron headed stroker with stock exhaust manifolds to 600hp at the flywheel? Anyone run a stroker without headers? Just wondering....thanks. :popcorn:
Re: What would I really lose?
« Reply #1 on: January 05, 2013 - 08:19:18 PM »
You will make a lot more torque even at low rpm with stock manifolds , I have done this on 2 cars that look bone stock but have killer 512s in them
Offline onebadfish
« Reply #2 on: January 05, 2013 - 08:29:24 PM »
Sounds interesting Neil, "killer 512"!
Offline cudabob496
« Reply #3 on: January 06, 2013 - 04:18:04 AM »
some head porting and a good mechanical roller cam should have you well above 500hp!
Actually, more cost effective to get the newer high flowing alum heads!
2011 Kawasaki Z1000
« Reply #4 on: January 06, 2013 - 06:16:04 AM »
you may not make the 600 hp but the midrange torque is nuts , I always port the manifolds as much as possible as well . it will still make power  :2thumbs:
Offline onebadfish
« Reply #5 on: January 06, 2013 - 01:28:03 PM »
Sound I run aluminum heads or have someone port/polish the 906s? Big torque monster - what cam specs?
« Reply #6 on: January 09, 2013 - 05:06:22 PM »
I would not run 906 heads , no quench .
 You can work a set of closed chamber 516 or 915 heads with large valves & port work which I would be happy to do for you if I was still there  :bigsmile:
 If you go Alum use a good head Super Stealth , Indy EZ , stay away from the Eddy Victors lots of hassles to make them work . If you are going alum might as well get a head with good flow #s not just a street version of the iron heads .
 Cam ? how long is a piece of string ? 4 types , flat tappet hyd or solid & roller hyd or solid . , I generally use a flat tappet solid with a similar grind to a mild roller , good durability & great powerband but youhave to set valves from time ot time
