Author Topic: Waterless cooling fluid  (Read 874 times)
Offline 4yuckfous
« on: January 05, 2013 - 06:22:29 AM »
Does anyone have experience with that?
Thanks for your feedbacks
The streets don't get wider, if you drive slower !
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: Waterless cooling fluid
« Reply #1 on: January 05, 2013 - 09:36:24 AM »
not yet.
 :popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn:
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #2 on: January 05, 2013 - 12:24:02 PM »
thats some cool stuff i might have finally found a way to eliminate my electrolysis problem in my dakota.
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
« Reply #3 on: January 05, 2013 - 07:58:41 PM »
Yes I have used it , works well
 we used Evans coolant , get 4 gallons
Offline 4yuckfous
« Reply #4 on: January 06, 2013 - 04:31:53 AM »
@Chrico Psycho
Thats the product what I was thinking about.
Witch one did you select?
Did you have rust water before on the coolant?
And after changing to the waterless fluid also?
We don't get Evans products in Switzerland :pullinghair:.
Does anyone know a other brand?
Offline cudabob496
« Reply #5 on: January 06, 2013 - 04:38:54 AM »
may lower engine output power. If removes heat better, will decrease cylinder temp and pressure, and may lower power,
depending on cam duration and other factors.  Better see some dyno tests. Alum heads would be more sensitive I would think.
I already run a higher thermostat due to my alum heads.
2011 Kawasaki Z1000
« Reply #6 on: January 06, 2013 - 06:17:13 AM »
it was a fresh build with a clean block so no water in the system at all .
Offline StRoKeR
« Reply #7 on: January 07, 2013 - 05:00:22 AM »
I always wondered if that stuff was good... It's pricey for sure.
Member Since January 14, 2004
71' Dart - 9 second All Motor Pump Gas Street Car! Full Interior, Full Exhaust, Raced on Local 93! 3400lbs.
72' Challenger - 10.67 @ 127.78 All Motor on 93 pump gas! 3850lb street car (SOLD)
