Author Topic: 1.5 Street Performance Shocks  (Read 1361 times)
Offline msbaugh
« on: January 05, 2013 - 09:44:34 AM »
Hotchkis changed over to a new shock absorber. Instead of the bilstein RCD shocks they now provide what they call a 1.5 street performance shock. The shock is manufactured by fox racing (the same company that makes the Baja suspensions and the suspensions for the new Ford Raptors). Apparently the fox facility is just north of the hotchkis site in California. They've been working together on the shocks tuning it and all that. The guy I talked to had their 70 challenger on two seperate road trips comparing the two, he said he liked the fox shocks much better. Ill say this though they cost an arm and a leg!! I ordered 2 to replace my air shocks so ill be able to comment on how I like them! I've rode in a new raptor and believe me, its unbelievable, so I can testify that fox makes only the best. I've been working my way up to the hotchkis tvs over the past few years so this will just put me one step closer
Re: 1.5 Street Performance Shocks
« Reply #1 on: January 05, 2013 - 02:44:14 PM »
Ya I've been talking with Dan over at Hotchkis too and they are fixed valving. Not adjustable, which would be fine for most cars. My issue is with the composite leafs they react much quicker than steel so I'm looking for an adjustable. Ridetech has almost the same shock ( also made by Fox) that is adjustable. HQ series.
http://www.ridetech.com/store/shocks/
« Reply #2 on: January 06, 2013 - 11:06:19 AM »
...and they are tuned specifically for 1.10 t-bars and 170 # leafs. They will still work with other rates, but the are optimized for those two and rates outside of that could benefit from better refinement (hence adjustable or revalved).
Offline 440STRKR
« Reply #3 on: January 11, 2013 - 03:10:59 PM »
I'm also looking to upgrade my shocks this year on my 72 chally. Do you have to run the hotchkis UCAs with the new shocks?
« Reply #4 on: January 11, 2013 - 07:35:57 PM »
 No you don't have to use the Hotchkis UCA's, they will fit with stock upper control arms. Same location as stock, similiar/smaller diameter as stock too.
Offline wiging19
« Reply #5 on: January 12, 2013 - 03:08:46 AM »
 :popcorn:
