Author Topic: rebuild carter hi perf fuel pump?  (Read 937 times)
Offline barracuda7199
  • needs a resto but having to much fun right now
« on: January 05, 2013 - 12:15:40 PM »
anybody ever rebuilt a carter street strip high volume mechanical fuel pump for a big block? the one i have worked good for a long time then not long ago it started pumping way to much pressure i mean like 15lbs! a new pump from mancini is probably 120 bucks once i get it and a rebuild kit is about half that. good idea to rebuild or am i just being cheap?
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline jimynick
Re: rebuild carter hi perf fuel pump?
« Reply #1 on: January 05, 2013 - 11:23:16 PM »
Brandon, laddie. We prefer to not think of it as "cheap", but as frugal, thrifty! Och aye!  :thumbsup: If rebuilding it wasn't a good idea, they wouldn't offer rebuild kits, now would they? Good luck   :2cents:
Offline cudabob496
« Reply #2 on: January 06, 2013 - 04:15:43 AM »
Holley makes cheap fuel pump discharge regulators! control the pressure with that.
« Last Edit: January 07, 2013 - 05:07:52 AM by cudabob496 »
2011 Kawasaki Z1000
