not sure how much longer it needs to be but you can figure it out Freezing temps in Panama , I doubt it
10-4 on it becoming obvious to me; and, Oh no, I meant they were calling for overnight freezing up here in Maryland last night -- and that you should be extra happy to be down there, in Panama! (My wife has her '66 GTO and now all she wants is for us to end up on FLA's Gulf Coast!)
One last question (for now) (that I hope I don't have to figure out)
Roughly how many (or, what range of) rpms are being referred to as, "high speed shifting" when some diaphragm clutches have gotten "stuck" in the down position?In other words, doing a lot of browsing since joining (learning as opposed to just lurking), it has occured to me that it might help other help me if I start stating my own driving habits, intended uses of my car, etc.
I don't race and am only highway crusin and showin' my car, right now; by any chance, will the fact that I don't anticipate shifting at any rpms over 4,000 reduce the chances of (if not preclude) my encountering the diaphragm clutch phenomenon of "stuck pedal"? Full story: I took the over center spring out of my car (against the mild protestations of my buddy / mechanic) after I installed a Mcleod diaphragm clutch.
Clutch action / pedal force required is a thousand times improved -- especially cosnidering the kind of traffic I am encountering until our planned move -- but, after several attempts at adjusting clutch, the clutch pedal has now (3x in 10 days) kept "returning" to a point where there is no freeplay in the pedal when its at rest.
I figure, what do I have to lose by putting the OC spring back in and trying to drive it that way, for awhile?
I realize that some Centerforce diaphragms have exhibited a tendency to have the pedal "stick" in the down position during at high rpm shifts but,
I am hoping the fact mine is a McLeod, combined with the facts that: a) my 440Magnum is routinely tached out at 3,000 to 3,500 rpm when I'm in 4th cruising at highway speeds (60- 75mph); and, b) since I don't race and don't imagine too many scenarios where I would ever shift at any rpm over 3,500 to 4,000 that, I may not even need to worry about the "stuck clutch".
Then again, I'm not sure what # the others are referring to as 'high' rpm's.
Thanks again and, Happy New Year!
