Well there is now fluid to the back brakes. Anyone that has a problem with K/H oem proportioning valve that cant be fixed, the wilwood valve is a great thing to use. Just take your time and think where to best put the valve, bolt it in place and give'er. Bolted mine on just below the original hole in the inner apron, there is an existing hole already drilled. Remade the left front brake line, spliced a short piece of 8 inch premade brake line, with a couple of bends, and using a inverted flare coupling, fastened the right front brake line.The rear one, cut of the 9/16 inverted nut from the exsiting line, mine was just long enough, and reflare on a 3/8 nut, supplied. Mount the master, cut off the 9/16 inverted nut from the front master cylinder line and reflare on a 3/8 nut, supplied. Do some engineered bending and twisting and there it is done. 2-3 hours tops and you should be in business. Took of the supplied brake switch and plugged it with 1/8 pipe plug. Dont need it, brake light switch is on the pedal. Wilwood number is 260-11179.
