Author Topic: pin in tie rod  (Read 1266 times)
Offline tony 73
pin in tie rod
« on: January 06, 2013 - 07:23:35 PM »
There is a hole in the end of my tie rods for a split pin, but there seems to be a rolled pin in there. I imagine the split pin should be of a good size. Do I try and knock the pin out or drill it ? What do you guys have in there.
thanks for the help, tony.
Offline cudazappa
pin in tie rod
« Reply #1 on: January 06, 2013 - 07:31:57 PM »
Proper size punch/ drift is the easiest way to get those out.  There isn't that much tension on them.
Not sure if the factory used a cotter pin or a split pin in them, though.
2015 Dart GT - Daily Driver
Offline jhaag
Re: pin in tie rod
« Reply #2 on: January 06, 2013 - 08:24:42 PM »
shoud be a castle nut with a cotter pin. someone has put a lock nut on there
love 70 Challengers
Re: pin in tie rod
« Reply #3 on: January 06, 2013 - 08:37:43 PM »
Are you sure about that? My strut rod had a roll pin in there. Maybe not original, but I thought it was.
Re: pin in tie rod
« Reply #4 on: January 06, 2013 - 08:41:42 PM »
They came with roll pins. They do punch right out to :wave:
Offline jhaag
Re: pin in tie rod
« Reply #5 on: January 06, 2013 - 08:50:16 PM »
you are right, he said tie rod and I really didn't look at the picture close enough. It is correct for a strut rod. my bad
love 70 Challengers
Offline tony 73
Re: pin in tie rod
« Reply #6 on: January 07, 2013 - 05:01:04 AM »
Great feed back as usual. My mistake for saying tie rod in the first place.
 So a rolled pin is the norm. Next question; Is the purpose of the pin to stop the lock nut from coming off ? My lock nut has been off and on a few times and only now when I was checking all my split pins did I notice the rolled pin. Should the rolled pin be longer ? do I need to replace them ?
 Thanks again, tony.
Offline jhaag
Re: pin in tie rod
« Reply #7 on: January 07, 2013 - 07:45:36 PM »
Far from an expert here, but common sense says if the nut hs been "on and off a few times", replace the nut. Also I would say the roll pin should protude on at least 1 side as a secondary safety to keep the nut from backing off. Seems redundant but I don't see any other reason for it to be there.
love 70 Challengers
Offline dutch
Re: pin in tie rod
« Reply #8 on: January 08, 2013 - 07:26:44 AM »
how tight should the nut on a strut rod be anyways?
*** Bart ***
Offline jhaag
Re: pin in tie rod
« Reply #9 on: January 09, 2013 - 07:55:09 PM »
Mine are long gone, but if I recall correctly, they have a shoulder and a sleeve so you would tighten them until you can go no further. If that is not right someone here will chime in.
love 70 Challengers
