Author Topic: Shaker sitting too high? Motor mounts?  (Read 1502 times)
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
« on: January 08, 2013 - 01:03:42 PM »
I was reviewing the "Shaker too low" thread and wanted to share a similar or opposite problem.  I did a conversion to shaker with a flat hood on my 70 Challenger.  Now has a 440 4-bbl with the shaker base from Dave at Roseville.
I suspect that my issue is caused by aftermarket motor mounts.   Has anyone experienced this issue and discovered a difference?   I used original mounts and isolation rubbers from Rick Ehrenberg of Mopar Muscle.
Thoughts or ideas?   I was thinking that I need to get the carb throat of the shaker base cut down about an inch, but don't want to do this if unnecessary.
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
Offline 72cudamaan
Re: Shaker sitting too high? Motor mounts?
« Reply #1 on: January 08, 2013 - 01:41:31 PM »
Are you sure you don't have the "B" air cleaner? They sit about an inch higher than the "RB" housing.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: January 08, 2013 - 01:51:28 PM »
What intake are you using?
Offline anlauto
« Reply #3 on: January 08, 2013 - 02:09:53 PM »
You could have a 383 or 340 shaker base. Also the intake/carb set-up might be the culprit. Trimming what you have might be the best idea. :dunno:
« Reply #4 on: January 08, 2013 - 03:26:13 PM »
 :iagree: http://www.nicksgarage.com/aircleaner.htm
Offline chaps70rt
« Reply #5 on: January 08, 2013 - 08:41:51 PM »
72Cudamaan ...... I was wondering this myself.   I did check with Dave at Roseville.   He believes I have the correct one.   If the other ones are shorter, perhaps I should simply swap for the 340 style .... or whatever is shorter??   Perhaps I will fire a PM to Dave again?
As for the intake.  It is a Edelbrock CH4B ...... I was told a couple of years ago that they would work with the shaker.   That is why I went this route.
Carb .... is a Holley.   I check with Performance Improvements and they told me that the Carter and the Holley I have are the exact same height.
The plot thickens .....    Hate the thought of cutting it down and removing a 1" section to maintain folded lip at the carb.
Thanks guys ......  CHAPS
BRAD ..... thanks for the link to Nick's Garage ..... wow .... lots of variations.  Unbelievable ....
440 - 4BBL - Shaker
Offline 72cudamaan
« Reply #6 on: January 08, 2013 - 09:08:09 PM »
 With the "B" version, the carb horn sits flush on a table surface. With the "RB", the carb horn is off of the table surface thus making the
housing sit lower.
Offline chaps70rt
« Reply #7 on: January 12, 2013 - 10:12:56 AM »
I did not know that ...... I am going to pull mine off the car this weekend and check it.
thanks 72Cudamaan!!!
Chaps   :cheers:
440 - 4BBL - Shaker
