Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Raise the front Cuda 1-3 " for 8qrt oil pan.
« previous
next »
Print
Pages: [
1
Author
Topic: Raise the front Cuda 1-3 " for 8qrt oil pan. (Read 2521 times)
71fish
Sr. Member
Bless you..
on:
March 07, 2005 - 09:57:25 AM »
I have "fat" profile 8 qrt tub pan. What is the best wat to raise the front of the car up 1-3". The pan is so low at this point.. even 1 "+ would help. I'm in the same position as revere & don't want to change tires. I have 15" rims around. N50's on the rear & 195 60's on the front. Didn't like the look of 70's in the front.. & don't think 75's would even fit.
I haven't played around with the torsion bars.. so could someone explain to me the best way to correctly addust the heightof the front w/o new tires?? TIA :beer:
71fish
Logged
71fish - Nobody better than an E-BODY!!
72cuda
Jr. Member
mmmmm, boiling gas
Re: Raise the front Cuda 1-3 " for 8qrt oil pan.
Reply #1 on:
March 07, 2005 - 10:42:28 AM »
You should be able to get 1"+ just by cranking up the bars, as long as you're not right at the end of the adjuster bolts travel.
Logged
72 Cuda 383 4-spd
Drive it like you paid for it
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
March 07, 2005 - 04:58:10 PM »
jackup the front end & lube the T bar adjusters & turn them clockwise, start with 4-5 turns , adjust as nessisary , this will alter the front end alignment slightly so you may need to realign the front wheels
Logged
71fish
Sr. Member
Bless you..
Reply #3 on:
March 08, 2005 - 08:17:27 AM »
Where are the "T-bar" adjusters"?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
March 08, 2005 - 09:29:41 AM »
it is a 4" long bolt with a 3/4" head inside the front control arm from below
Logged
72cuda
Jr. Member
mmmmm, boiling gas
Reply #5 on:
March 08, 2005 - 10:53:23 AM »
CP's adivce to lube the adjuster bolts is well taken - if they haven't been touched for a while, those guys can be a bear, even with the suspension unloaded.
Floor jack, 3/4" socket and breaker bar and you're golden.
Logged
72 Cuda 383 4-spd
71fish
Sr. Member
Bless you..
Reply #6 on:
March 10, 2005 - 02:26:18 PM »
OK.. Thanks guys.
:beer:
Logged
71fish
Sr. Member
Bless you..
Reply #7 on:
May 16, 2005 - 02:42:55 PM »
Thanks.. looks as if I got 2-3", but the engine isn't in yet either.. but I can def see a difference. Thanks for the help.
Logged
OUTLAW
MASTER OF ALL THINGS MOPAR
Sr. Member
I didn't say you can't RACE--I said you can't WIN
Reply #8 on:
May 16, 2005 - 03:11:47 PM »
just as a note and I dont know if this holds true to all but its 6 complete turns to an inch
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #9 on:
May 17, 2005 - 02:43:59 AM »
it varies with the stiffness of the bar
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
