Author Topic: Looking for front drum hub diameter  (Read 538 times)
Offline Haddixj
« on: January 10, 2013 - 05:01:00 AM »
I am looking for the diameter of the hub where the drum slides on. Even the inside diameter where the drum slides on will work  Does anyone have this or a set of calipers handy? I am trying to piece together a brake kit using srt8 calipers and either srt rotors or Benz rotors.
Offline Haddixj
Re: Looking for front drum hub diameter
« Reply #1 on: January 10, 2013 - 06:25:13 PM »
Got it when I got home it's 2.81" so the 13" Benz rotor only needs .172 bored out of the center and should slide on.
Offline 73restomod
« Reply #2 on: January 13, 2013 - 01:14:40 AM »
Should be 74.5 mm, but ill double check.
Sent from my DROID RAZR using Tapatalk 2
