Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Caliper location '74 E-body
« previous
next »
Print
Pages: [
1
Author
Topic: Caliper location '74 E-body (Read 1299 times)
dwbiggs
Full Member
on:
March 07, 2005 - 10:48:52 AM »
I am rebulding front end and can't remember if there is a right or left spindle and as a result would dictate if the calipers would be positioned toward the front of car or rear of car on spindle. Been too long since I tore all that apart...guess I shoulda shot some pics. If I check for a PN on the spindles would a PN ending with an odd number mean the spindle goes on left side and even on right?
Thanks,
Dan
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Re: Caliper location '74 E-body
Reply #1 on:
March 07, 2005 - 02:00:29 PM »
The Calipers are positioned towards the rear of the rotors. I believe the inner brake pad will be slightly larger than the outer too.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
dwbiggs
Full Member
Reply #2 on:
March 07, 2005 - 02:10:19 PM »
Thanks,
Seems I am getting conflicting opinions on this from different sources. I guess when I get home I will try the PN thing to determine which spindle goes on left or right.
Dan
Logged
MEK-Dangerfield
C-C.com Expert
Reply #3 on:
March 07, 2005 - 04:42:47 PM »
Dan,
After kicking this around in my brain now, I'm not sure about that brake pad statement I made.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
March 07, 2005 - 05:02:03 PM »
depends which system you have , the 70 had the lines going straight into the caliper & the caliper has to be forward on the spindle for the brake hose to fit or you will need custom longer brake hoses
Logged
RUSTY Cuda
Sr. Member
One big step foward!
Reply #5 on:
March 07, 2005 - 06:09:01 PM »
Mine (74) are hung in front, scratchin my head on the different pad thing also, remember it mentioned but not which went where! :dontknow:
Logged
Screwy Squirrel
Jr. Member
Reply #6 on:
March 07, 2005 - 06:55:24 PM »
april's 72 cuda has the calipers toward the front of the car. seems exactly a CP says. as for the pads, all 4 look the same. hope this helps
joe
Logged
RUSTY Cuda
Sr. Member
Reply #7 on:
March 07, 2005 - 07:38:30 PM »
Ok, went to the service manuel. the outboard shoe is thinner than the in board,this is on the sliding caliper system(or so the book says!) I'm no expert thats why I bought the manuels! :dontknow: Rich.
Logged
dwbiggs
Full Member
Reply #8 on:
March 08, 2005 - 10:02:48 AM »
Thanks everyone for the replies. I think I will try mounting on front...talked to a buddy of mine with a '74 Challenger yesterday and his are on the front. I am using pin type calipers BTW.
Dan
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
