Author Topic: cuda hood yes or no  (Read 11432 times)
Offline cudamadd
    • cudamad157071@gmail.com
cuda hood yes or no
« on: January 11, 2013 - 10:09:20 PM »
My cuda came from the factory with out the hood pin option.   I do like the hood pins . So i am at the 50/50 stage , do i put them in or do i leave it plan ?  Do most of as think they like better with or with out pins , cheers. :dunno:
Go 4 a spin Ya Why Not.
Offline TorOrange
Re: cuda hood yes or no
« Reply #1 on: January 11, 2013 - 10:29:50 PM »
I like them and I would install them if it was my car. Unless it's a flat hood doesn't look as good then.  :2cents:
WANTED 71 cuda / barracuda project. Prefer Black but open.
Offline Cuda Cody
  • Vancouver, WA
« Reply #2 on: January 11, 2013 - 10:31:12 PM »
Rallye hood, yes.  If you like them, put them on!
Offline edl94
  • She Cuda
« Reply #3 on: January 11, 2013 - 10:32:08 PM »
I installed the pins on my 73. Debated for a long time, if you like the look go for it.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: January 11, 2013 - 10:43:41 PM »
Makes the car look more sporty, IMO.
Without hood pins:
With hood pins:
Oh, I just noticed the pic, has a hood tach too!!!  Don't see that often!  :grinyes:
Offline anlauto
« Reply #5 on: January 11, 2013 - 11:01:18 PM »
Hood Pins were STANDARD ON ALL 1970 AND 1971 CUDAS !
They were not optional at all on any Cuda from 1970 -1974.
They were optional only on 1970 and 1971 Challengers.
Big mistake leaving them off on most clones made like to above examples. :pullinghair:
If your car is a 1972-74 and didn't come with them, YES you should add them, nothing looks cooler :bigshades:
Make sure you do it correctly with the proper "Cuda" only hood pin brackets and proper lanyards etc...  :2cents:
IF YOUR CAR IS A 1970 or 1971 THEN YES IT SHOULD HAVE THEM FACTORY INSTALLED.  :cheers:
« Last Edit: January 11, 2013 - 11:12:40 PM by anlauto »
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #6 on: January 12, 2013 - 09:27:18 AM »
my 71 barracuda came with hood pins from the factory with the flat hood. its an odd car EV2, black vinyl top, luggage rack, column shift, and road lamps with a 318 and a 904. i like the hood pins especially the factory ones on all the cuda hoods.
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline go-fish
« Reply #7 on: January 12, 2013 - 11:05:46 AM »
You mean the bracket which is mounted to the radiator core support? The one that the pin screws into. You're not saying all 1970 and 71 Cudas rolled out of the factory with the pins, scuff plates and lanyards installed?
Are you differentiating between 'cuda and Barracuda?
« Reply #8 on: January 12, 2013 - 11:18:07 AM »
I just looked at a 1970 Barracuda brochure and it describes the Cudas having hood lock pins, not mentioning being optional equipment.  Didn't know that.  I thought they were option only type things as you see many '70 Cudas without the hood pins...  :dunno:
Also for 1970, Cudas got front and rear sway bars.  Challenger R/Ts only got front from the factory for 1970 if I'm not mistaken....  :dunno:
Read the brochure in the link below...
http://www.oldcarbrochures.com/static/NA/Plymouth/1970%20Plymouth/album/1970%20Plymouth%20Barracuda-06.html
« Reply #9 on: January 12, 2013 - 11:23:50 AM »
Found this for 1971 in a Barracuda brochure.  Hood pins were "standard" on the Cudas!  I didn't know that!    :thumbsup:
Man, the Challengers got short changed!!!!   :roflsmiley:  And I have a '72 so I'm even more short changed!!!  No big blocks, less HP, less options... :stomp:
http://www.lov2xlr8.no/brochures/mopar/71bara/bilder/8.jpg
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #10 on: January 12, 2013 - 11:25:49 AM »
I actually don't like them.
I'd use them on an aar hood but I personally would leave them off of any other hoods.
 :2cents:
Offline anlauto
« Reply #11 on: January 12, 2013 - 11:32:17 AM »
YES I am....ALL 1970 and 1971 Cudas had hood pins ALL BS23?0 and ALL BS27?0 and ALL BS23?1 and ALL BS27?1 cars.
Offline go-fish
« Reply #12 on: January 12, 2013 - 11:34:35 AM »
Wow, didnt know.
Offline Katfish
  • 70 Challenger
« Reply #13 on: January 12, 2013 - 12:55:34 PM »
Cuda or Barracuda, put'em on!
Offline swede-cuda
« Reply #14 on: January 12, 2013 - 03:10:48 PM »
 :clueless:
actually i think cudas built before january 1 did not get rear sway bar.  :clueless:
