Author Topic: brake hose for slider caliper  (Read 669 times)
Offline rockymopar
« on: January 12, 2013 - 12:22:28 AM »
I am gathering parts to put the big Cordoba rotors and slider calipers on my Challenger. I was wondering if anyone knows if the existing E body brake hose will work, and if not, what particular donor car should I order a hose for. Thanks
Offline 73restomod
Re: brake hose for slider caliper
« Reply #1 on: January 12, 2013 - 02:08:10 AM »
It does, however I don't recommend reusing the old ones.
Sent from my DROID RAZR using Tapatalk 2
Offline 74challenger03
« Reply #2 on: January 12, 2013 - 07:40:17 AM »
the brack lines are like $9 at the auto store. I agree dont use the old ones.
Offline Katfish
  • 70 Challenger
« Reply #3 on: January 12, 2013 - 08:04:13 AM »
Did this awhile ago, so prices may be higher now.
I bought eveything for my Challenger at local Advanced Auto. If you order online, you'll get free shipping.
raybestos w/pad RC4103/4 $36.00
78 charger (slider)
outer bearing BR2 $6.00
78 charger
wearever rotor YH141132 $52.00
78 charger
dorman banjo bolt 13938 $5.00
inner wheel bearing BR17 $8.00
77 charger
inner seal 19500 $2.00
77 charger
raybestos hose 4536755 $15.00
76 duster
« Reply #4 on: January 12, 2013 - 09:15:57 AM »
there are different slider calipers available , , some use a flare type fitting some use a banjo type , so you need to match the right hose .
Offline rockymopar
« Reply #5 on: January 12, 2013 - 12:57:12 PM »
Thanks for the tip guys. Now it is time to break out the kroil penetrant to get the factory bolts and fittings loose
