News:
I used two 20" long, 60 lbs gas struts on mine (with the AAR spoiler mounted). Without the AAR spoiler, 40 lbs works... I know this because once I bolted on my spoiler I had to go up in size. Mine are bolted to the rear seat bulkhead. If you mount them somewhere else then you'd need shorter ones.No twisting since I have one strut on each side. If you tried to do it with just one strut then you might have a problem with twisting??? Travis72 Cuda
