Author Topic: Idle raises when warmed up?  (Read 2283 times)
Offline 72cudamaan
Re: Idle raises when warmed up?
« Reply #15 on: January 14, 2013 - 01:16:24 PM »
  :popcorn:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 422STROKER
  • Member Since 6/3/06
« Reply #16 on: January 15, 2013 - 08:55:11 PM »
I was thinking as your beast motor warms(smooths) up it's making more vacuum thus bringing timing in on the manifold vac port and raising rpms?  Just a thought.
Tom
Tom
Offline jhaag
« Reply #17 on: January 15, 2013 - 09:48:26 PM »
wondering the same on the vacum connection. even if it doesn't fix the problem it needs to be connected to ported vacum, otherwise at wide open throttle you have low or no vacum. that defeats the purpose of a vacum advance. dist connection needs to be above the throttle blades.
love 70 Challengers
Offline 422STROKER
« Reply #18 on: January 15, 2013 - 10:04:53 PM »
At WOT there won't be any vacuum either way(ported or manifold).  Some use the manifold vac to add some initial timing at idle to smooth out some issues. fwiw.
Tom
Tom
« Reply #19 on: January 16, 2013 - 09:50:22 AM »
I thought  mopars ignition/dist were engineered around manifold vacuum? 36*-38* total at 3000 and dial in/out needed advance at idle with the vacuum advance adjustment.  :clueless:
Offline 422STROKER
« Reply #20 on: January 16, 2013 - 06:05:23 PM »
AFAIK it's ported vacuum that way there is no timing added at idle.
Tom
Tom
« Reply #21 on: January 16, 2013 - 06:18:08 PM »
I haven't had a chance to mess with it yet but I forgot to add I only get 5-6 inches of vac at idle?
Offline 422STROKER
« Reply #22 on: January 16, 2013 - 07:58:37 PM »
Warmed up vs Cold?
Tom
Tom
« Reply #23 on: January 16, 2013 - 08:25:00 PM »
Warmed up vs Cold?
Tom
About the same. I have to feather it for a minute of two before it runs on it's own due to no choke.
Offline 422STROKER
« Reply #24 on: January 16, 2013 - 10:36:50 PM »
How about timing at idle?  Cold vs warm settings?  Check the timing at the warm high idle vs cold idle as the vacuum is connected.
Just bouncing ideas.  I assume you checked throttle cable for burrs and the return spring is sufficient to pull back.  Any vacuum leaks at intake or carb?
Tom :popcorn:
Tom
Offline jimynick
« Reply #25 on: January 16, 2013 - 11:20:36 PM »
How's that mean mother running, by the way? I imagine that it's a bit of a monster. Heehee! Watch out for the OPP!  :thumbsup:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #26 on: January 17, 2013 - 07:32:53 PM »
Yeah I was going to say vacuum leak as well.
Check it while cold and see what the delta is when warm.
Otherwise you may have one of those temperature sensitive springs on your throttle!!!
 :roflsmiley:
« Reply #27 on: January 17, 2013 - 09:29:56 PM »
I'm pretty sure there are no vac. leaks , sprayed card cleaner around and found nothing. I'm thinking it's in the distributor. Right now we are in a deep freeze so I won't be starting it for awhile.
