Author Topic: Timing question  (Read 902 times)
Offline LukeSkywalker
  • Plymouth
Timing question
« on: January 13, 2013 - 03:51:23 PM »
Here's a control question, just so I don't ruin anything have to check with you guys
440 Engine.
When C is where it sits in the picture and the CAM is set to 'A' then DISTRIBUTOR is supposed to fire at '1' right?
And when CAM is at B, then DISTRIBUTOR is supposed to fire at '6' right?
Because that is how it stands right now..
Offline 72cudamaan
Re: Timing question
« Reply #1 on: January 13, 2013 - 08:24:12 PM »
If "A" is your original timing dot for the cam then yes that is correct.
If I cant fix it, it's broke
Andy  (phukker whither)
Re: Timing question
« Reply #2 on: January 13, 2013 - 08:42:51 PM »
a=1
b=6
  • Plymouth
Re: Timing question
« Reply #3 on: January 17, 2013 - 06:29:48 PM »
Thanks  !
Offline 74challenger03
Re: Timing question
« Reply #4 on: January 17, 2013 - 06:51:55 PM »
what does C=   sorry guys but I couldnt resist .
Offline cudabob496
Re: Timing question
« Reply #5 on: January 19, 2013 - 04:16:51 AM »
maybe crank at 0 degrees with #1 piston at TDC?
2011 Kawasaki Z1000
Offline 72cudamaan
Re: Timing question
« Reply #6 on: January 19, 2013 - 09:49:05 AM »
winner winner, chicken dinner.  :cooldancing:
Offline Changin Gears
Re: Timing question
« Reply #7 on: January 19, 2013 - 10:27:44 AM »
The easiest way to double check whether the rotor should be pointing at 1 or 6 is to point it at the one with both the intake and exhaust valves fully closed.
