Author Topic: Stereo Radio only sound on one side?  (Read 860 times)
Offline Mopar_Mudder
  • I'm a llama!
« on: January 13, 2013 - 08:04:34 PM »
I have an AM/FM stereo thumb wheel radio for a 1971 Cuda. Finally got far enough to hook it up and their is only signal coming from the Left channel, nothing out of the right. Balance seems to work as I can fade out the signal from the left, but get nothing to the right.
Anything easy to look for or do I have to send it in?
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
Offline TinCuda
    • 'Cuda
Re: Stereo Radio only sound on one side?
« Reply #1 on: January 13, 2013 - 09:30:45 PM »
It maybe the radio.  Here is a wire diagram if it helps you.
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Offline Jamiez
  • Retro
« Reply #2 on: January 13, 2013 - 09:45:07 PM »
Are you sure the speaker works?  If you can try swapping the right and left connections.
If it does I would hook a multi meter to the output and see if there is any signal on the wire at all.
Maybe you are lucky and its something easily replaceable like the cross over box
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #3 on: January 14, 2013 - 12:39:20 AM »
the contacts inside the fade control might benefit from a quick spray of WD-40....the contacts tend to oxidize from long periods of non use and humidity.
have you ever turned the volume control up and got static and erratic levels of volume?  wd-40 will fix that...or any contact cleaner.
hope you get it figured out.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
  • I'm a llama!
« Reply #4 on: January 14, 2013 - 10:42:06 AM »
Yes I have already verified that it is at the radio by swaping wires around at the 3 pin connection. Doing that I can get sound to the right side if I use the left out put of the radio.
1971 Hemi Cuda
  • I'm a llama!
« Reply #5 on: January 14, 2013 - 10:43:09 AM »
Go idea I will give that try.
1971 Hemi Cuda
