Author Topic: Gas gauge troub;e  (Read 671 times)
Offline Robhimselfff
Gas gauge troub;e
« on: January 14, 2013 - 10:37:54 AM »
So this may seem like a general circuit question but the gas gauge in my 70 Challenger isn't working.  The ground to the tank is good and so is the wire to the unit so I'm thinking it could be the power or ground  to the gauge? Just looking for a second opinion before I start ripping my dash apart.
Re: Gas gauge troub;e
« Reply #1 on: January 14, 2013 - 10:50:40 AM »
If all your other gauges work. then I would suspect a bad sending unit first. If you have access to an Ohm meter, check the resistance between ground and the screw-like peg. It should be between 10 and 70 Ohms.
« Reply #2 on: January 14, 2013 - 11:12:44 AM »
Check the ground strap from the sending unit hose to the stock steel hose on the body. If it's corroded or missing the gauge won't work.  Looks like this.
http://www.rosevillemoparts.com/product_info.php/p/sending-unit-ground-strap-correct-length/products_id/4118
Offline 72cudamaan
« Reply #3 on: January 14, 2013 - 01:11:17 PM »
Also check for voltage at the sender connection.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline _Russ_
  • Not very family friendly!
  • Chk Chk Boom!
    • Show Me How To Live
« Reply #4 on: January 14, 2013 - 10:37:01 PM »
When you say "isn't working" do you mean completely dead/no movement at all? or reading incorrectly? (reads half full when full etc)
« Reply #5 on: January 15, 2013 - 12:08:57 AM »
If it is dead I would start at the sender & see if you are getting a pulsing voltage there if not trace towards the front / connecters , gas guage connection & if the other gauges are working the voltage reg must be ok
