Author Topic: Burnt bulkhead connector, and some general wiring Q's.  (Read 8594 times)
Offline _Russ_
  • Not very family friendly!
  • Chk Chk Boom!
    • Show Me How To Live
« on: January 14, 2013 - 11:07:58 PM »
OK, so I have some questions regarding a new wiring harness, and I though it best I start a new thread to keep it all in 1 place, rather than hijack others threads.
Here is the original thread I began when my Challenger's problems first occurred: Diagnosing a "miss" - fuel or electrical?. Engine dieing. Towed home. Starts a couple days later. Repeat. Multiple times over the past couple months. I thought it may have been the ignition, but also went through the fuel system. The "miss" was fixed by proper timing & advance adjustments, but it still cut out on me.
Matt is having a similar problem in his thread here.
After reading some thoughts in his posts, and other threads linked to regarding the Ammeter gauge and burnt bulkhead connectors, I started with my bulkhead connector and noticed part of it is burnt through. Can anyone recognise what that port/wire is used for?
An auto-electrician had previously told me I was getting a voltage drop from this area (but he didn't specify which wire), as well as this fusible link:
With the burnt bulkhead connector, and some old looking wiring, Ive decided to replace the engine wiring harness. Here are a few questions.
1) I'll be getting the M&H Harness from YearOne. I have electronic ignition, but will be switching to a complete aftermarket electronic ignition (ICE Ignition). The YearOne link mentions that "If using an aftermarket electronic ignition system, our manufacturer suggests that a reproduction harness for point ignition would be a better starting point." Is this correct?  Any thoughts on why that would be the case? (I'm not doubting it. Just curious).
2) Does anybody reproduce the 70 E-Body bulkhead fuse box? (The bit that's burnt in the above image). I don't believe this is included in the new harness, and I'll need to replace it.
3) Regarding the Ammeter bypass, I read on a Charger forum that Redline Gauge Works will actually convert your factory Ammeter gauge to a Voltmeter gauge. Has anybody had this done? Successfully? I'd much prefer that than aftermarket gauges.
I'll probably have a few more questions as I go. This should be enough to get me started.
I appreciate your time and any thoughts.
I've never been able to wrap my head around electrics. My aptitude for this sort of thing is best when I have someone experienced next to me and teaching me first hand on the job, as apposed to reading books and looking at diagrams that I can't make heads or tails of  :grinyes:
 :cheers:
Offline don340-4
Re: Burnt bulkhead connector, and some general wiring Q's.
« Reply #1 on: January 14, 2013 - 11:24:06 PM »
  I think my M&H dash harness came with a new fuse box, my connectors looked like yours, I replaced the engine & light harness too, everything is good now. M&H is really good quality.
     :wavingflag:
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
Offline anlauto
« Reply #2 on: January 15, 2013 - 07:23:58 AM »
Reaplace ALL harnesses with new M & H and be done with it.
It's a little expensive, but so is standing on the side of the road watching your car burn to the ground....  :villagers:
Offline don340-4
« Reply #3 on: January 15, 2013 - 12:31:33 PM »
Don
2012 Ram 1500 R/T
Offline _Russ_
  • Chk Chk Boom!
« Reply #4 on: January 15, 2013 - 04:11:01 PM »
Yeah that sounds like the sensible option. Unplugged everything at the bulkhead connector and found another burnt out port, which I believe is the troublesome Ammeter connection. Could be the very source of my problems.
New M&H Engine and Dash harnesses on the way.
Offline johannes
« Reply #5 on: February 20, 2013 - 01:28:16 PM »
Be aware of other connectors also !
I strongly recommend to run a wire in parallell with the AMP-meter....
Effectively running from alternator output, to battery +.
The movement of the AMP-meter needle will be reduced, but there WILL still be indication as to charging or draining the battery
Offline _Russ_
  • Chk Chk Boom!
« Reply #6 on: February 20, 2013 - 07:20:36 PM »
That's actually what my auto-sparky did.
Fit the new ICE Ignition system, but run a wire from the ALT directly to the battery to take off some of the load. Car is now moving under its own power with excellent spark. Just need a dyno tune to get it tip-top.
Offline 72ls5fla
« Reply #7 on: February 21, 2013 - 12:16:56 AM »
I just did the M&H main harness and engine harness on my car.
I had the same short situation and mine actually came close to catching fire.
The M&H harness is excellent reproduction.  No issues with connections/terminals missing etc..
I did have to reuse my fuse block section (not bulkhead) from my old harness so I could get my horn relay (correct 1970) to plug in.
The bulkhead (part screwed to the firewall) was the same -
You can use the new harness as shipped by using the horn relay they ship with the harness - there is a tab on the side that you will need to remove to make clearance to plug into the fuse block.
Be sure you put PLENTY of di-electric grease into the bulkhead (female connections).  This will keep moisture from getting in plus stop arching from dry loose terminals.
Just an FYI --   fit the new engine/lamp harness connectors to the bulkhead before you put the main harness in the car.  you may need to massage things a little to get them to clip down correctly..
FWIW --  I would do the forward lamp harness too ..    you will get a new fusable link wire section plus the plug for the bulkhead will be new and clean.
The harnesses are all discount allowable from YearOne.   I would wait for a 20% or 30% off web sale.  I saved enough on the main harness to basically get the engine harness and a good bit of the lamp harness for free...
Bill
« Last Edit: February 21, 2013 - 12:26:18 AM by 72ls5fla »
