Author Topic: what bore master cylinder do i need?  (Read 1422 times)
Offline barracuda7199
  • needs a resto but having to much fun right now
« on: January 16, 2013 - 09:46:44 PM »
i am looking to swap an aluminum 2 bolt master cylinder on my 71 cuda. i have the adapter plate already the car was an original manual drum brake car. I swapped to 73 and up disc spindles with the 10.89 rotors and pin calipers. the rear brakes are 11" drums with new shoes and 7/8" wheel cylinders. i really wish i could have found some 12" rotor caliper adapters when i did this swap about 9 years ago...
what bore master cylinder do i need? i have a few on the shelf how do i measure them? with a dial caliper measure the inside where the pushrod goes?
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Re: what bore master cylinder do i need?
« Reply #1 on: January 17, 2013 - 07:52:58 AM »
I'd ask Cass aka DrDiff? He set me up with 1 1/32" bore M/C  for my combo?
« Reply #2 on: January 17, 2013 - 08:23:12 AM »
How is your pedal effort? Is it like pushing on a brick wall?
Brandon
« Reply #3 on: January 17, 2013 - 08:42:30 AM »
You do have to push , but I am using manual brakes? :dunno: I have most of the parts to convert to hydroboost, just haven't got around to it yet? HB uses a bigger M/C  1 1/8" I think Cass set me up with?
« Reply #4 on: January 18, 2013 - 05:03:35 PM »
well the master i had wouldn't work it wasn't machined for the pushrod retainer. so i got the same one as you brad from dr diff not a bad deal when you know what he has will work. i will just put the adapter i have now up for a later project.
Brandon
« Reply #5 on: January 18, 2013 - 05:06:16 PM »
 :2thumbs:ya Cass is a big help!
« Reply #6 on: January 26, 2013 - 12:09:31 AM »
a little follow up on the dr diff master cylinder. everything fit great the pedal effort feels good to me and the adapter plate was the right thickness so i could reuse my stock manual brake pushrod. anybody in the market for a new master cylinder should give cass a call or just buy from his ebay store great guy to deal with.
Brandon
