What oil filters do you run?
Author Topic: What oil filters do you run?  (Read 11064 times)
Offline shadango
Re: What oil filters do you run?
« Reply #45 on: April 07, 2013 - 06:18:22 PM »
FWIW, I run a WIX 51068 on my SB WITH the 90 degree adaptor (picture says "w/o")
Offline shadango
« Reply #46 on: April 07, 2013 - 06:24:02 PM »
Offline 74 challenge
« Reply #47 on: April 09, 2013 - 08:03:02 AM »
When I bought my car ~3 years ago it came with half a case of Quaker State Oil filters. I have been using those up.
1-8-4-3-6-5-7-2
Offline BIGSHCLUNK
« Reply #48 on: April 14, 2013 - 12:01:27 PM »
Heres a pic to show I do what I say........
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline high perf mopar
« Reply #49 on: April 14, 2013 - 12:11:56 PM »
this is what i use,,jomar 100% no bypass competition filters..
http://www.hughesengines.com/Index/products.php?browse=search&search=jomar&searchmode=keyword&page=2&partid=23365
JPP 9025
FILTER, OIL NO BYPASS SPIN-ON
SPIN ON OIL FILTER. 5.50' IN LENGTH. BE SURE YOU HAVE ROOM!!!
$13.95
Hi-Flow filtration system- 100% no bypass.
This is the only MOPAR filter available with no internal bypass valve!
100% NO-Bypass design protects engine from debris resulting from components failure!
Fits all Mopar "LA", Magnum and Big block applications.
Extra thick housing for higher burst strength (600psi!).
Standpipe & anti-drainback valve for added protection.
20-micron element for FULL filtration with a minimum restriction.
Up to 50% more filter area than other premium filters.
This Pro-Filter in independent test using Mobile-One 10W30 at 70º temperature, flowed 8 GPM with only an 8psi pressure drop.
This filter is 5.50" long and will not fit on the Dakota or Durango trucks. This fits great on all full size Ram trucks. Fits most older LA, B and RB engines but you should check before ordering. We cannot accept returns on oil filters.
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline aris_unlimited
  • Project in full swing
« Reply #50 on: April 15, 2013 - 12:28:56 PM »
I run mobil 1 filters on my other cars. Right now I just buy whatever is cheapest for my satellite lol. I'll start putting the good stuff in after the motor is redone.
Cuda is gone :(
74 satellite, daily driver/project now
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
« Reply #51 on: April 15, 2013 - 08:16:08 PM »
Hastings. That is what my mechanic recommends. And he has been working on all my Mopars for over 12 years.i trust his opinion .
