Author Topic: will these pushrods fit?  (Read 671 times)
Offline willard
    • 1970 Challenger R/T
« on: January 20, 2013 - 07:39:17 AM »
Finally I measured my pushrods and they are 0.125" too long. I found this auction:
http://www.ebay.com/itm/350585996044?item=350585996044
I guess these are gonna fit my 383 with stealth heads and lunati lifters with stock rockers?
1970 383 R/T SE
Re: will these pushrods fit?
« Reply #1 on: January 20, 2013 - 08:02:25 AM »
Too many variables to know for sure? If you know that every pushrod is .125" to long then I would say you can measure what you have and get one 1/8" shorter?
I'd get an adjustable pushrod and check for sure.
Offline Changin Gears
« Reply #2 on: January 20, 2013 - 08:53:11 AM »
I made my own adustable pushrod to check lengh out of some all-thread, a couple of nuts, and an old cut up pushrod...
Offline willard
« Reply #3 on: January 20, 2013 - 09:06:00 AM »
I already checked w/ pushrod checker and I need 8.450". My question was abiut that specific jesel pushrod - it's shaped a bit different than normal ball-ball pushrod.
1970 383 R/T SE
Offline Aracer
« Reply #4 on: January 21, 2013 - 11:11:52 PM »
I think that an actual, round ball / ball will clear more lift @ the rocker. But you have to determine the durability of the item for your setup. The price seems low enough. One important Mopar thing is the lack of oil hole.
« Reply #5 on: January 22, 2013 - 05:34:33 AM »
I'm wondering if the ball on the ends are the required radius? :dunno:
Offline willard
« Reply #6 on: January 22, 2013 - 09:36:22 AM »
I have only lunati 220/226 cm with less than 0.5" of lift so nothing fancy needed here.
1970 383 R/T SE
« Reply #7 on: January 22, 2013 - 10:09:00 PM »
If you need 8.450, those Jesel ones will work without any problems.  You must have some shaved heads and a decked block?
