Author Topic: Suggestions on 440 upgrades...  (Read 3541 times)
Offline gafletch
Re: Suggestions on 440 upgrades...
« Reply #15 on: February 03, 2013 - 11:58:37 AM »
 :). Wow, thanks for the awesome feedback. I appreciate it. This was previously a race engine. All I know is it had aluminum heads before it was tamed for the street. Greg
Offline cudabob496
« Reply #16 on: February 04, 2013 - 04:17:37 AM »
Here's an article on installing roller cams.
Don't see any need to remove block from car?
http://www.moparmusclemagazine.com/techarticles/engine/mopp_0001_how_to_install_a_hyraulic_roller_cam/viewall.html
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #17 on: February 04, 2013 - 10:57:47 AM »
So what you are saying is that you want to put a new roller cam in a 40 year old motor with 40 year old cam bearings?
Offline cudabob496
« Reply #18 on: February 04, 2013 - 07:28:26 PM »
no, didn't say that. just saying I was not aware of a requirement to pull a motor to install a roller cam.
what if motor is well maintained and is only 5 or 10 years old?
« Last Edit: February 04, 2013 - 07:34:25 PM by cudabob496 »
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #19 on: February 04, 2013 - 08:52:12 PM »
It really depends what the owner wants to do but with the top end (lifters, rockers)  you have everything you need to make the swap without much effort. As for the cam, I wouldn't personally do it but there are others under some circumstances would.
Offline cudabob496
« Reply #20 on: February 05, 2013 - 02:46:21 AM »
Greg here in Cincinnati area wondering what suggestions you have on upgrading my '70 440 Cuda.  It's .040 over so about a 448 ci? Forged crank and rods, Lunati Bracketmaster II hyd flat tappet cam, M1 Mopar intake (7" high), Holley 750, Doug's headers, MSD ignition, iron heads with light porting, 727 manual shift auto, 410 Dana.
I figure low twelves right now. I wanna keep it streetable. Any suggestions on upgrades? ( I do have nos but it isn't finished yet).  I bought it already built like this.  Thanks, greg
3500 stall converter
when you smash the throttle, it doubles the torque to the rear wheels!
But you wanna have a cam that makes power in the higher rpms, like above 3000.
Also, adjust your timing curve.
Also saw an article that showed adding the proper stall converter added 75 hp to the engine output.
« Last Edit: February 05, 2013 - 03:13:06 AM by cudabob496 »
2011 Kawasaki Z1000
