Author Topic: 440 RPM / Stock carb. kickdown slackrod modification.  (Read 488 times)
Offline Aracer
« on: January 21, 2013 - 10:59:13 PM »
Just enough room for WOT, and some slack for a choke setup. This also fits under the stock flat hood. (1974 B.)
Offline cudabob496
Re: 440 RPM / Stock carb. kickdown slackrod modification.
« Reply #1 on: January 22, 2013 - 12:08:10 AM »
Nice! But sure was nice to dump all that stuff, and go to a manual valve body. Which also
gives harder crisper shifts, which prolongs tranny life.
2011 Kawasaki Z1000
Offline Aracer
Re: 440 RPM / Stock carb. kickdown slack rod modification.
« Reply #2 on: January 29, 2013 - 10:24:32 PM »
I did remove the kick down linkage from my LA 1968 Cuda.
I'll dig out the picture. It still has both E & A, throttle brackets piggy backed.
This 440- 1974 cuda is for strip-now /street-later, so its only got a shift improver kit / 4.30 ratio (for now) and it needs a kick down.
