Author Topic: carburetor  (Read 1872 times)
Offline cameron2502
carburetor
« on: January 22, 2013 - 05:42:28 PM »
What brand is every one using, have a 71 cuda 408 stroker motor, fed up with trying to make a ede.....k work, does anyone else have a 408 stroker and what are you using, is the proform brand any count or quick fuel. thanks.
Offline cudabob496
Re: carburetor
« Reply #1 on: January 22, 2013 - 05:50:23 PM »
seems a Holley HP 750 DP mechanical secondaries would make you the most power.
Ya, EDe's don't make big power from my experience
2011 Kawasaki Z1000
Offline cameron2502
Re: carburetor
« Reply #2 on: January 22, 2013 - 06:14:46 PM »
this is driven on the street most of the time. thanks
Offline cudabob496
Re: carburetor
« Reply #3 on: January 22, 2013 - 08:30:58 PM »
understand, but there are times on the street when you want to put your foot into it.
All depends what your goals are I suppose. I have built my street Cuda to go as fast as
possible, and not lose to anyone, if possible. (All within a budget of course).
I accept there is always someone who can beat you. It just hasn't happened yet.
I may be immature, but I just don't like to lose.
Probably any 750 Holley will make you all the power you can use. Maybe some good
deals on Ebay. Otherwise, Summit seems to have the best prices.
« Last Edit: January 22, 2013 - 08:34:39 PM by cudabob496 »
2011 Kawasaki Z1000
Re: carburetor
« Reply #4 on: January 22, 2013 - 08:38:46 PM »
I'd suggest a proform or quickfuel carb and a air/fuel ratio gauge to tune it with. Those two carbs  have much more adjustablility than a standard Holley. :2cents:
Offline cudabob496
Re: carburetor
« Reply #5 on: January 22, 2013 - 08:53:42 PM »
Had thought that Holleys win more races at the track than any other carb?
2011 Kawasaki Z1000
Re: carburetor
« Reply #6 on: January 22, 2013 - 08:55:30 PM »
They are based on the Holley design. Just with more adjustments.
Offline EddieE
Re: carburetor
« Reply #7 on: January 22, 2013 - 10:00:21 PM »
Just fitted a Holley Ultra Street Avenger
770 CFM with vacuum secondaries on a 340 stroked to 416.  Engine dyno's at 465 HP and 530 ft/lbs.  I replaced an Edelbrock Performer 750.  The car runs smoother and stronger than the Edelbrock, which fell on its face fro 1000 to 1500 RPM with an Edelbrock air Gap Manifold.
Buy or borrow this carb.  I did not TOUCH it other than bolting it on...no adjustments.
Offline jimynick
Re: carburetor
« Reply #8 on: January 22, 2013 - 10:47:46 PM »
What the man said. The new Holleys have all the idle and air bleed adjustments that the others do. That doesn't mean the carb tuner's carbs aren't worth it; it just means they're usually a significant amount of money, more. Carbs can be like women- pick the one that makes you happy and that works for/with you. Good luck.
Offline cudabob496
Re: carburetor
« Reply #9 on: January 23, 2013 - 02:59:18 AM »
 on my old 440 Cuda, going from a 750 EDE to a 750 Holley DP picked me up about 30 hp.
2011 Kawasaki Z1000
Re: carburetor
« Reply #10 on: January 23, 2013 - 09:42:18 PM »
the Proforms are usually a bit cheaper then the Holley , my pick is Proform
Offline cudabob496
Re: carburetor
« Reply #11 on: January 24, 2013 - 02:21:48 AM »
http://www.summitracing.com/parts/pro-67201/overview/
Pretty nice! Question is, what does the Holley have that this doesn't? I think a Holley is almost
$200 more?
2011 Kawasaki Z1000
Re: carburetor
« Reply #12 on: January 24, 2013 - 06:59:18 AM »
FYI Proform and quickfuel are the same company.
Offline cameron2502
Re: carburetor
« Reply #13 on: January 24, 2013 - 10:17:15 AM »
thanks guys, I appreciate all the help.
« Last Edit: January 24, 2013 - 12:52:39 PM by cameron2502 »
