Author Topic: 72 cuda turn signal bulb socket  (Read 1273 times)
Offline Madmaxx
« on: January 25, 2013 - 10:38:07 PM »
i have one turn signal giving me grief...its the bulb socket..old kinda rusty..have cleaned it  only works when you mess with it...where can i get a new one..tired of messing with this one..it looks kinda unique..but maybe..it was that 4th beer...help!..thanks!
Re: 72 cuda turn signal bulb socket
« Reply #1 on: January 25, 2013 - 11:18:22 PM »
An option to try is to soak in Evaporust overnight.
Then use electrical contact paste.
Evaporust is available at Harbor Freight. Small jug is like 8-10 bucks.
Electrical contact paste is found usually at O'rielly's on the front counter.
Offline JayBee
« Reply #2 on: January 26, 2013 - 09:24:42 AM »
I had an issue once with an iffy back-up light. Mine turned out to be a poor ground between the socket and taillight housing.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Madmaxx
« Reply #3 on: January 26, 2013 - 12:36:02 PM »
hey guys i appreciate the reply's..after cleaning the socket..the bulb is super loose and the bottom fiber or plastic that holds the brass leads in place so it contacts the bulb elements is junk...if i cant find anything suitable as a replacement i will probaly work on saving it...it unplugs from the harness so nice..a new one would replace it so nicely!!..lol maybe i'm dreaming..
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #4 on: January 26, 2013 - 03:22:59 PM »
Keep an eye out.  You will find a new one here.
Offline Madmaxx
« Reply #6 on: January 30, 2013 - 09:02:15 PM »
hey jaybee thanks for the link!...but i'm not smart enough to give you all of the details..its in the front!!..argh!..its a twist in one..i'm going to look alittle closer at it i think?..but thanks for the effort!
Offline Madmaxx
« Reply #7 on: March 10, 2013 - 11:22:32 PM »
ok guys i found my problem!..i decided i was going to replace this dam socket..sooo i decided to take apart the one giving me grief...i cut the plastic covering that is around the wires at the base of the socket..and i found that the single wire conector (ground) had a broken tab..so no complete ground...it was trying to ground thru the housing i guess..anyway...i sand blasted the socket and then soldered the grd tab to the housing..retaped it up and guess what a functioning turn signal!!!! before it would work on flashers but not turn signal..hope that one helps someone else!!
Offline JayBee
« Reply #8 on: March 11, 2013 - 09:28:27 AM »
Glad to hear you got it solved.   :2thumbs:
John
2014 Toyota Avalon
