Author Topic: Better Venting of Cooling System  (Read 478 times)
Offline cudabob496
« on: January 27, 2013 - 06:32:30 AM »
I saw a tip in PHR magazine that I actually had tried a few years ago, and had good results.  To remove trapped air
in your cooling system, which may be causing hot spots, drill an 1/8 inch hole in the flat steel portion of your
thermostat. It helped my engine run cooler!
2011 Kawasaki Z1000
