A833 transmission issue
Author Topic: A833 transmission issue  (Read 5555 times)
Offline hiway star
Re: A833 transmission issue
« Reply #15 on: February 04, 2013 - 12:26:54 AM »
Does the reverse light stay on whenever the key is on even if you unplug the switch at the trans?  If so, you need to look at the wiring going from the firewall down to the trans switch.  If the reverse light comes on when you step on the brakes, use turn signals or  headlights,  make sure your taillight housings are properly grounded to the body.
Offline 1BADFISH™
« Reply #16 on: February 04, 2013 - 03:09:41 AM »
Thanks Hiway Star, I think its only staying on when the key is on but I will have to double check, i'm starting to confuse myself now lol.   :crazy:
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
Offline LAA66
« Reply #17 on: February 04, 2013 - 08:17:26 AM »
 Had a similar problem and it tuned out the wires melted on the headers.
