Author Topic: VIN plate rivets  (Read 11213 times)
Offline Haddixj
Re: VIN plate rivets
« Reply #15 on: January 29, 2013 - 08:02:45 PM »
So it's just riveted into the foam? Not the metal frame?
« Reply #16 on: January 29, 2013 - 08:44:38 PM »
The foam in the VIN plate area was as thick as two flat washers.  I cut the foam out and put the washers in its place so there was nothing to compress when I installed the rivets.  The rivets on my VIN plate go through two flat washers and then down through the dash frame.  The tag is attached to the metal frame.
