Author Topic: reed holley carb?  (Read 1782 times)
Offline barracuda7199
  • needs a resto but having to much fun right now
reed holley carb?
« on: January 28, 2013 - 10:42:24 PM »
has anybody ever heard of a holley carb tuner by the name reed? the carb on my cuda has reed stamped on the main body and the metering blocks. the main body has no choke and is contoured like a proform or a quickfuel. it works very well just not sure what the cfm rating is i bought it from a swap meet years go on the cheap. it is a double pumper with only the front block having idle adjustments so i don't think its to exotic. i will get a pic or two of it in the morning if that will help. thanks for everyone's time!
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline cudabob496
Re: reed holley carb?
« Reply #1 on: January 29, 2013 - 03:44:07 AM »
2011 Kawasaki Z1000
« Reply #2 on: January 29, 2013 - 10:11:28 AM »
thanks for the lead! i will send them an e mail. here are some pics of the carb.
Brandon
« Reply #3 on: January 29, 2013 - 03:10:05 PM »
Measure the throttle blades and that will help you drill down to possible sizes.
Offline cudabob496
« Reply #4 on: January 29, 2013 - 10:01:50 PM »
I think the reed carbs were 830 cfm
2011 Kawasaki Z1000
