Author Topic: Edelbrock Performer RPM Heads and Rocker Arms  (Read 3806 times)
Offline Ca70Cuda
« on: January 29, 2013 - 02:30:43 PM »
Hello, after firing up my 440 last weekend, I noticed that I have a hair line crack in my one of my 906 heads. It's a horizontal hair line crack (about .375 in length) that leaks coolant, located just below the exhaust ports (where the machined flat exhaust port surface meets the casting surface of the head). The 440 is basically stock with a mild hydraulic cam. Instead of replacing the cracked 906 head, I am thinking about purchasing a new set of Edelbrock 60929 Performer RPM Heads. These heads include the valve train except the rocker arms. Here is my question:
Right now, my current heads have non adjustable rocker arms. If I were to purchase the 60929 Edelbrock Heads, would I need to switch to adjustable rocker arms?
The 440 was built several years ago and I have no idea what the cam specs are. If I have to go to adjustable rocker arms then I have to figure out the cam configuration to properly adjust the rocker arms. I have never had adjustable rocker arms before and I just think they would always be a pain to adjust. Maybe I am wrong. I guess if I have to switch to adjustable rocker arms than any suggestions for what rocker arms to purchase would also be much appreciated.
Thank you!  :thumbsup:
« Last Edit: January 29, 2013 - 02:58:24 PM by Ca70Cuda »
2012 Blackberry Pearl RT Challenger
2011 Tungsten Rallye Challenger
1970 Cuda, Yellow
1969 Roadrunner, Orange
1969 Roadrunner, White
Offline Bart
Re: Edelbrock Performer RPM Heads and Rocker Arms
« Reply #1 on: January 29, 2013 - 03:12:22 PM »
I put the Indy heads on my 383 with the same intake and used PRW 1.6 rockers no problems with them and easy to adjust.
http://paceperformance.com/i-5147928-prw0231812-prw-stainless-steel-roller-tip-rocker-arm-kit-mopar-273-360-1-6-1-ratio.html
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
« Reply #2 on: January 29, 2013 - 11:23:19 PM »
Why not use the Stealth heads for 1/2 the $ or use the Super Stealth over the Eddy .
I believe the stock rockers & pushrods work ok but the ratio is not perfect & I would recommend the adjustable arms anyway .
Offline cudabob496
« Reply #3 on: January 30, 2013 - 01:08:00 AM »
how about a $7 bottle of alumaseal?
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: January 30, 2013 - 12:29:30 PM »
Super Stealth require the offset intake rockers (.650" to be exact)
Don't ask me how I know....
Offline PlumCraZRT
« Reply #5 on: January 30, 2013 - 12:38:56 PM »
I would recommend buying bare stealth heads and having them cleaned up and assembled by a trusted shop.
mmmmm.... Mopar.... *drool*
Offline 72cudamaan
« Reply #6 on: January 30, 2013 - 01:37:14 PM »
Didn't read the fine print huh?   :roflsmiley:   Sorry, had to do it.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: January 30, 2013 - 01:43:08 PM »
Actually worked out for the better, the harlands had them and they are bad assed.
No cheap out on this motor build.  :2thumbs:
