Author Topic: Order of shortest 4bbl 440 intake manifolds  (Read 9343 times)
Re: Order of shortest 4bbl 440 intake manifolds
« Reply #15 on: March 01, 2013 - 06:32:44 AM »
 :o  I'm no expert but I would never mount a coil under a fuel line. Recipe for a Mopar BBQ?  :scared:
Offline cudabob496
« Reply #16 on: March 01, 2013 - 06:57:11 AM »
hmmm, have to think about that.  The portion of fuel line it is under is just a piece of chromed steel.  And the coil tower
does point to the passenger side fender. But will chew on that.
I knew there was a reason I had a fire extinguisher on board!
« Last Edit: March 01, 2013 - 07:17:01 AM by cudabob496 »
2011 Kawasaki Z1000
Offline Bart
« Reply #17 on: March 01, 2013 - 09:51:23 AM »
Yea need to move that just did know at the time where to mount it but you are correct on the Mopar BBQ. Alwats carrier a fire extinguisher in the car.......
Will move the coil...
Thanks
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
Offline cudabob496
« Reply #18 on: March 01, 2013 - 07:52:59 PM »
I suppose with a long enough coil wire, they can be mounted anywhere.
Just depends on how short you have to keep the coil wire.
Actually, your location is good as far as keeping the coil cooler.
2011 Kawasaki Z1000
Offline 73restomod
« Reply #19 on: March 04, 2013 - 10:17:26 PM »
Old school tricks is to run a partial divider in the Plenum ( from the bottom of the carb down), doesn't have to go all the way top to bottom just enough to deflect the pressure wave from affecting the entire carb.
Sent from my DROID RAZR using Tapatalk 2
