Author Topic: Rallye Dash Wiring Layout pictures  (Read 5677 times)
« on: February 02, 2013 - 10:59:29 PM »
Schematicss get tedious looking at.
Some wires and connectors get tricky and time consuming tracking down on a schmeatic.
If you've have pictures of your dash all wired up, would like to see them.
Preferably the 70-71; Rallye dash layout.
Offline bentpshrods
  • Almost there, Boise Id.
Re: Rallye Dash Wiring Layout pictures
« Reply #1 on: February 03, 2013 - 11:39:16 AM »
  These are from my 71/rallye dash when I was replacing the pad. Car is coming along nicely. Are you going to to have it out this summer?
« Last Edit: February 03, 2013 - 11:43:57 AM by bentpshrods »
« Reply #2 on: February 03, 2013 - 11:56:18 AM »
Thanks for the pictures.
It's out right now getting assembled & re wired up.
Do you have any of the switch panel? I want to make sure the switches aren't unside down.
Offline 72ls5fla
« Reply #3 on: February 03, 2013 - 03:00:41 PM »
hope this helps...
Offline high perf mopar
« Reply #4 on: February 03, 2013 - 03:17:00 PM »
if your dash assembly is like mine with a fresh coat of paint on it,do yourself a favor and run a ground wire from the back of the gauge housing,not the dash frame,to tie in with the body ground,,that will eliminate 1 major gauge function problem that these cars have,,alot easier to do it on the bench b-4 installation..i tied mine in at the motor frame ground,,along with a ground wire from the gas tank sending unit all meeting with wire from the battery ground..12-14 gauge wire will be your friend..
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
« Reply #5 on: February 03, 2013 - 03:30:21 PM »
hope this helps...
Yes that does. That explains also the orange to yellow. There was one male terminal with nothing connected on the wiper switch. I can see now nothing goes to it all.
Thanks.
« Reply #6 on: February 10, 2013 - 01:10:02 AM »
I was able to figure out most of the wiring today on my dash.
A few questions I couldn't find in my book.
Does the switches look like they are positioned right side up?
I already presume the wiper switch is upside down.
What is this plug go to? Was this some option?
What connected to it?
« Last Edit: February 10, 2013 - 01:14:11 AM by Topcat »
Offline 72ls5fla
« Reply #7 on: February 10, 2013 - 07:58:10 AM »
thats for the radio
« Reply #8 on: February 10, 2013 - 11:15:25 AM »
Thanks.
that makes sense.
« Reply #9 on: February 16, 2013 - 11:23:58 PM »
hope this helps...
I haven't been able to verify this connector on a schematic about yours.
When I received my re-built Tach, the male terminal was on the upper location,
Mr. Heaterbox I heard has a good reputation. Why would he switch the location of the male terminal vs. yours?
A mistake or difference?
For now, I'm confused what goes where on the tach.
Hopefully I will get this figured out.
Offline halle09
« Reply #10 on: November 07, 2013 - 02:28:36 PM »
so i dont understand the whole tach thing there were two wires running to mine and it didnt work i just wanna know if anybody found out what all the terminals wer? Ground coil neg,accessory etc so i can just say screw it and make new ones
« Reply #11 on: November 07, 2013 - 10:24:06 PM »
Call Mr. Heaterbox. He should be able to help you out.
http://mrheaterbox.com/instrument_clusters.htm
« Reply #12 on: November 09, 2013 - 09:28:57 AM »
Run a separate ground white for your switch panel as well.  It will save you a headache down the road. I ran one from the steel switch backing plate down to the kick panel area and mounted with a star washer/screw
Offline HP_Cuda
  • Mopar or No Car!
« Reply #13 on: November 09, 2013 - 01:09:01 PM »
Isn't part of your problem the ground strap on your wiper isn't doing the job?
