Author Topic: Putting Grease in bulkhead Female Connectors.. 1970 Challenger  (Read 1464 times)
Offline 72ls5fla
« on: February 03, 2013 - 03:10:06 PM »
hello--
I am about to put in a new M&H main harness.
I was always told to pack grease into the bulkhead connectors to create a tight seal  etc..
What type of grease should I use?
Should I put it into the female side or slop it into the male connectors?
Also - would it hurt anything to grease the connections for the turn signal and ignition switch (white plastic parts) at the column?
Thanks in advance.
Bill
Offline 72cudamaan
Re: Putting Grease in bulkhead Female Connectors.. 1970 Challenger
« Reply #1 on: February 03, 2013 - 04:06:45 PM »
Dielectric grease is what you want.  put it in the female side. Use it anywhere that may get corrosion
or moisture.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 72ls5fla
« Reply #2 on: February 03, 2013 - 04:11:38 PM »
thank you ....
do you know where I can purchase Dielectric grease from?
Bill
Offline Jamiez
  • Retro
« Reply #3 on: February 03, 2013 - 04:16:43 PM »
It's used on pretty much any electrical connectors so you can probably get it from any electrical supply place/home center/or automotive shop.  I checked and autozone lists several different products on their website.
Offline 72cudamaan
« Reply #4 on: February 04, 2013 - 08:24:17 AM »
Yeah, any auto parts store will have it.
Offline Changin Gears
« Reply #5 on: February 04, 2013 - 12:27:43 PM »
It's commonly sold for use on trailer to tow vehicle conection  plugs.
Offline 73EStroker
« Reply #6 on: April 01, 2013 - 08:05:57 PM »
White lithium grease. Available everywhere but get some in a squeeze tube. Spray can is too messy. I use it on all my connections with no issues anywhere.
Barry (Salmon Arm)
Offline tommyg29
« Reply #7 on: April 01, 2013 - 09:07:39 PM »
I used dielectric grease in my connectors too. Figured it can only help promote a consistent connection.
Can buy it at any electrical supply or the electric dept at home depot.
Comes in a squeeze tube
« Last Edit: April 01, 2013 - 09:09:32 PM by tommyg29 »
Offline Strawdawg
    • Vortex Buicks
« Reply #8 on: April 01, 2013 - 10:10:00 PM »
silicone grease is a dielectric and can be bought at most parts stores...it seals moisture out of the connector so the contacts don't corrode
I understand it should not be used where contact pressure is very low as in some weatherpack style connectors but I have used it with no problem on bulkhead units in the past
« Last Edit: April 01, 2013 - 10:52:31 PM by Strawdawg »
