Author Topic: center carb  (Read 1927 times)
Offline aarman
  • Newbie
  • I'm a llama!
center carb
« on: July 02, 2002 - 11:24:59 AM »
need help in adjusting center carb for six-pack setup.how do i set my idle screws?when i start it up,the butterfly sticks open and runs full throttle.any help would be greatly appreciated.  ;D
Re:center carb
« Reply #1 on: July 02, 2002 - 12:39:51 PM »
  First find out why the throttle plates are sticking ,is the correct gasket under the carb or is the carb or gasket twisted so that they bind.
Once you get that fixed you can turn the idle screws in until you hear the idle speed drop then turn the screw out until the rpm quits increasing. there are also idle screws in the end carbs under the fuel bowls pointed straight forward in the base plate , these are usually  set 1/2 turn ot from bottom & often are  sealed with metal plugs over them.
Offline Rare_T_A
    • Freiss Family Mopar Site
Re:center carb
« Reply #2 on: August 23, 2002 - 02:13:52 PM »
Hi,
Go to my web site and click on T/A articals and then six pak carb tips. This artical was very helpful to me. The pages will be readable when you download them.
http://freiss.tripod.com
'09 Challenger R/T  5.7 HEMI Auto
'70Challenger T/A 340 727
Fargo, N. Dak.
My web Site:  http://freiss.co.nr
My Flikr Page: http://www.flickr.com/photos/102813164@N04/
I was born with nothing and I still have most of it left!
