Author Topic: Getting Time to Call Dr. Diff: what did you buy?  (Read 6072 times)
« on: February 05, 2013 - 10:12:13 PM »
I'll be calling Dr. Diff later this month (around Feb 25) to put in an order on a Dana 60.
What did you do if you bought from him?
Specs, Options chosen. Advice.
thanks
Re: Getting Time to Call Dr. Diff: what did you buy?
« Reply #1 on: February 05, 2013 - 10:30:26 PM »
I bought the truetrack , HD tapered bearings and retainers, 35 spline axels, rear disc brake kit with aluminum caliper brackets 3.55 gear ratio, e brake cables.
Rear end was supplied with this cover but I didn't like it...
so I bought this one in stainless from summit auto racing...
http://www.summitracing.com/parts/KTL-304M60/?rtype=10
To save myself a few bucks I ordered my own rotors that matched the fronts I already had and did my own machining for the oversize bearings. Cass uses Toyota rotors and they need the centers machined to suit the axel hubs. Cass can have this all done for you, I just elected to do it myself.
« Reply #2 on: February 05, 2013 - 10:39:41 PM »
That looks sweet Brad.
I'd like to stay at or around or under $3,500 delivered.
Is that doable for what you did?
« Reply #3 on: February 05, 2013 - 10:42:41 PM »
Yes I think that is pretty close to what I paid?
Offline 67vertman
  • Member since 9-23-2005
« Reply #4 on: February 05, 2013 - 11:25:35 PM »
Mike,
Here is what I got.
Bolt-in, E-body spec 5-60 assy 4.10 track lock, 1350 yoke and std cover  $1875
Upgrade to True-Trac differential        $300
Repro pinion snubber plate        $75
Cordoba 10 inch rear disc  brake kit                                                          $275
Shipping        $245
You may also need, brake lines, new u joints, U bolt yoke
« Reply #5 on: February 05, 2013 - 11:38:38 PM »
Mike,
Here is what I got.
Shipping        $245
That sounds like kinda what I may do except go for 3:54. Need the pinion snubber added also.
So now it comes down to the main question:
For now staying with OEM 23 spline 4 speed. But if in the future, I decide to change to a 5 speed (Passon)
Would I need to upgrade my gear in my diff to a 4:10 to get the gear range in the tranny suitable for the Hemi?
It's a 485 c.i 426 stroked with a semi lifted cam. Nothing too radical.
Offline 67vertman
« Reply #6 on: February 06, 2013 - 11:12:27 PM »
Mike, That is what I did, I went with the 4:10 now and will be updating to a 5 speed (Passon) when they hit the street.
I will live with the high RPMs for freeway driving for now.  :grinyes:
Offline Mopar_Mudder
  • I'm a llama!
« Reply #7 on: February 07, 2013 - 02:15:45 PM »
Don't know if he is still around or making them but I got mine from a guy called Greg Sanford. grgs.rearends@yahoo.com
Depending on how original you want he converts truck rear ends so they don't have the correct machined surface for the snubber.
dana 60 hd E body mopar
new 410 ring and pinon
35 spline powerlock posi
35 spline axles
new 1350 yoke
new stock cover
Set-up for Right Stuff disc brakes. Did not include the rear disc as I bought that as a complete kit front to back, but he did sell them also.
It was right aroun $1900 back in 2010
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
Offline anlauto
« Reply #8 on: February 07, 2013 - 07:15:24 PM »
I buy ALL my rear axle parts from Cass. Great guy to deal with :2thumbs:
« Reply #9 on: February 08, 2013 - 09:44:32 AM »
There is the opton to use offset spring hangers & move the springs inboard & use a B body spring pad width for more tire clearance
« Reply #10 on: February 08, 2013 - 10:28:00 PM »
 :iagree:  I forgot to add this is the route I went with the new Dana.
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #11 on: February 11, 2013 - 09:24:05 PM »
the b body rearend is the way to go if you want some meat under there! i have 325's under my 71
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
« Reply #12 on: February 11, 2013 - 10:12:47 PM »
If I decided to do the B body Dana, what Year One Rallye wheel (the new one's just released) offset in the 17" size would you recommend?
« Reply #13 on: February 11, 2013 - 10:21:39 PM »
My rims are 15x10 with 5.5" back space. I have a 1/4 spacer on the passenger side. but most every car is tight on one side to the spring or quarter.
Brandon
« Reply #14 on: February 11, 2013 - 11:57:12 PM »
Brandon,
Could you possibly throw a few pics up to give me insight how it looks/sits?
Would be good to see.
Thanks
