Author Topic: How to restore 3spd wiper motor?  (Read 4952 times)
Offline Tonker1
« on: February 06, 2013 - 04:46:15 AM »
Hey,
I've taken a look around on-line and found nothing, so does anyone know of a step by step 'how to restore 3spd wiper motor engines'?
Mine is currently wired with a mix of insulated chicken wire and real copper wire, so performance if variable to say the least. I'm essentially trying to pull out the bits of the engine and replace the wiring harness but everything inside the engine can seems relatively fragile and stuck in place.
Has anyone successfully done this before?
I'd rather do it myself than pay some else, I just don't have the money at the moment.
Thanks
Offline Kapteenikosmos
Re: How to restore 3spd wiper motor?
« Reply #1 on: February 06, 2013 - 07:27:06 AM »
I fixed and cleaned mine couple of years ago. Sadly I didn't take any pictures but I still remember some things that you should pay attention while doing it. I dissassembled the gearing and the electric motor and cleaned up the gunk and rust. I also replaced some of the wires. If I recall right, the field wires are quite tricky to replace and in my motor those were in somewhat ok condition so I left them in original shape. I did fix some of the insulations there because the original ones had crumpled away.
Remember to mark the orientation of the gearbox cover because it can be installed in couple of positions for different cars. One thing that I battled with was the parking feature of the wiper motor. Inside the gear box is a mechanism that operates a longish copper contact that is used so sense when and where the wiper should park. The contact should be normally closed and the mechanism opens it (if my memory is correct). Mine was probably bent during the dissassembly and it didn't make contact so the parking was not working. E-body shop manual has some information about the wiper motor that I used to help with the troubleshooting.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
« Reply #2 on: February 06, 2013 - 08:17:58 AM »
A rebuilt one from autozone is roughly $67
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #3 on: February 06, 2013 - 12:24:57 PM »
If you give up, and want someone else to restore it, then i suggest Kim at http://www.passion4mopars.com/
Maybe she can sell you parts if you are still set on doing it yourself.
She does fantastic work!!!
Offline BIGSHCLUNK
« Reply #4 on: February 06, 2013 - 12:52:29 PM »
Had mine redone by KIM @ passion.......  :2thumbs:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: February 06, 2013 - 01:09:37 PM »
They have 2 speed ones as well?
Offline shawge
  • Zoiks!!
« Reply #6 on: February 06, 2013 - 03:41:15 PM »
Yellowfin, you wouldn't happen to have a part# for the Autozone rebuilds, would you?  Their website doesn't have any listings for "wiper motor"
- Jerry
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #7 on: February 06, 2013 - 05:16:12 PM »
2 speed listed as 40-382 and is $48
3 speed listed as 40-362 and is $67
Offline Tonker1
« Reply #8 on: February 07, 2013 - 05:42:08 AM »
I considered the fully restored option by passion4mopars, but I don't require a visually perfect window wiper motor, it would also be the cleanest thing in my engine bay!
Thanks Yellow Fin, $67 is hard to say no to. I'm now considering buying the wiper motor as opposed to wasting a couple hours fiddling.
Offline TinCuda
    • 'Cuda
« Reply #9 on: February 07, 2013 - 06:07:24 AM »
Tag for later    :popcorn:
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #10 on: February 07, 2013 - 07:05:49 AM »
No problem, glad I could help!
Offline solarguy
« Reply #11 on: February 07, 2013 - 09:38:47 AM »
Is that autozone 3 speed wiper motor set up for an E body with correct bulkhead plug and park location?  Also, can the 3 speed motor be used as a variable motor?
Offline dutch
« Reply #12 on: February 07, 2013 - 10:26:58 AM »
What can be expected from a 67 buck motor? One can hardly open and close it for that...let alone restore it properly   :clueless:
I would  recomment passion for mopars as well
*** Bart ***
Offline passion4mopars
    • Passion4mopars
« Reply #13 on: February 07, 2013 - 07:37:31 PM »
I do "repairs" as well.  If you're happy with the way it looks, I can go through it, resleeve the wires from the winding to the switch plate, make sure it's clocked correctly, gear is not broken, has three speeds and parks....granted that's more than $67, but it's not a full resto price either.  Normally $125 or under unless there's something that needs to be replaced and if that's the case, I'll take photos of the broken components and send them back with the repaired motor...as a woman I wanna see my old parts so I KNOW they were replaced  LOL  I've had shops in the past tell me I had a muffler bearing going bad.  Really?  But the rekanooter valve is good?      :roflsmiley:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #14 on: February 07, 2013 - 08:29:17 PM »
But you forgot about the piston return springs.... :stirpot:
