Author Topic: Car came with no keys  (Read 675 times)
Offline dfark
  • Hold on to your lugnuts, time for an overhaul
« on: February 09, 2013 - 10:44:00 AM »
I've just realized that my car has no keys with it.    I suppose I can purchase a new key switch for the column and matching locks for the doors and trunk?    Maybe that is a good thing to eliminate any electrical issues with the old switch.  Is this stuff available through the aftermarket suppliers? :dupe:
72 Challenger project
05 Dodge Cummins 3500
Offline tx9aarcuda
Re: Car came with no keys
« Reply #1 on: February 09, 2013 - 10:53:43 AM »
Call Roseville Moparts they are a sponser here. They are great to work with, excellent customer service. Here is a link to there web site
http://www.rosevillemoparts.com/index.php?osCsid=304b73e74a0e095e03a61e2f00dce9d2
Greg
68 Coronet R/T Convertible 4 spd
70 AAR Auto
97 Ram 1500
Offline 72cudamaan
« Reply #2 on: February 09, 2013 - 11:28:41 AM »
You could have a locksmith make a key for the ignition. If done right, it will work in all of the other cylinders. What electrical issues do
you think you may have with the lock cylinder?
If I cant fix it, it's broke
Andy  (phukker whither)
Offline dfark
« Reply #3 on: February 09, 2013 - 01:19:19 PM »
I was thinking there could be electrical issues with the ignition switch, not so much the lock cylinders themselves,  as long as they are not stuck from years of neglect
« Reply #4 on: February 09, 2013 - 11:28:26 PM »
A locksmith can make you a key , how did youget the c`ar there without though , steering should be locked ?
The locks may still match after 40 years but do not bet on it , not hard to have them all keyed alike again though .
The Ign lock & the electrical switch are different units , the lock drives the switch but has nothing to do with the electrical part .
Offline dfark
« Reply #5 on: February 10, 2013 - 09:23:13 AM »
Oh I see.  You can tell I haven't messed with it much.    On our farm equipment the key switches have all the electrical on the switch and can cause problems after years of service.  Thanks for your help.  By the way my steering column is not locked,  I winched right up on the trailer and steered it both ways.
Offline jimynick
« Reply #6 on: February 10, 2013 - 11:35:25 PM »
A good locksmith will pull a door cylinder and code the ignition off it. If you drove the car with the steering lockout not engaged, either you are in the "on" position or you've got larger problems.  :2cents:
