A couple of Challengers in the St Louis area: a 440-6 and a Hemi (clone)
Author Topic: A couple of Challengers in the St Louis area: a 440-6 and a Hemi (clone)  (Read 3522 times)
Offline RzeroB
  • In The Lou and looking for a new (old) ride
A couple of interesting Challengers for sale in the St Louis area. I don't own either one; I came upon ads for them on Craigslist. They both look very nice. Price for each of them is in the mid $50K's. Too pricey for me, but maybe someone else is looking for something just like these two cars. If you are interested I would be more than happy to help out in any way that I could.
The first one is advertised as a 1970 Challenger RT with a 440-6
http://stlouis.craigslist.org/cto/3567106677.html
The second is advertised as a 1971 Challenger RT with a Hemi (clone)
It is no longer advertised on Craigslist, but here is a link to a Photobucket albumn of the car
http://s1087.beta.photobucket.com/user/tomravak/library/Hemi%20E-Bodies/1971%20Hemi%20Challenger%20clone
There was a '70 Challenger RT convertible with 383 for sale too. It was super nice and in the $50K's too. It must have recently sold for the ad is no longer up. Coincidently, all three Challengers were finished in FE5 Bright Red.
« Last Edit: March 17, 2013 - 09:44:59 PM by RzeroB »
Cheers!
Tom
St Louis, MO
Former owner of 16 classic Mopars. "It is better to have owned (Mopars) and lost then to have never owned at all" (apologies to Alfred Lord Tennyson)
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: A couple of Challengers in the St Louis area: a 440-6 and a Hemi (clone)
« Reply #1 on: February 09, 2013 - 07:34:57 PM »
what are the odds, they are both the exact same price
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline 1BADFISH™
« Reply #2 on: February 09, 2013 - 10:29:52 PM »
Pretty nice looking cars, I wonder if the 6 pack cars is a real v code?
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
Offline RzeroB
At the behest of a CC member, I went and looked at the '71 Hemi Challenger "clone". John, the owner, has a large shop with a lift so I got to inspect the car from bumper to bumper, inside and out, and underneath. When I was done inspecting the car we took it out for a test drive of about 5-6 miles or so. The car was originally a non-descript 318 auto car. Here's my impressions of the car:
Body: driver's floor, trunk pan, trunk extensions, one front fender, trunklid and both rear quarter panels were replaced. The body is super-straight with all the body lines and panel gaps aligned properly. Given the extent of the metal work done on this car it turned out exceptionally nice. If John didn't tell you what was replaced you would be hard pressed to figure it out on your own. Whoever did the body work did a super nice job. About the only issue with the body is with the doors. Both the left and right doors line up properly when closed but "droop" slightly when opened (relatively common issue). When closing you can hear the jamb striker rubbing on the top edge of the door latch which causes them to require a little "effort" to close them.
Paint: The car was painted in FE5 Rallye Red using a modern catalyzed base-coat clear-coat paint. The paint is very nice over the entire surface of the car. It is not a super-shiney high gloss "show" finish like you might find with many coats of hand-rubbed laquer. Instead, it has a nice shiney lusterous gloss to it as I imagine they had new from the factory. There are not any runs, drips, sags, ripples or "orange peel" anywhere on the car. The car was rotisseried and the underside of the car is fully painted and looks very nice too. Whoever body and paint person was, he was very good.
Exterior Trim:  Bumpers are straight and the chrome looks good. Grille and lower valance look good. Wheel lip, drip rail, hood edge and trunk lid edge stainless mouldings look new. The right side drip rail moulding front edge (where it goes into the door jamb opening and ends just above the upper door hinge) didn't appear to be installed correctly. The moulding end tab is sticking up when it should be "tucked" underneath the windshield moulding. The "Challenger" script on the tail panel between the tail lights is old. The tail lights are new but reflectors that are part of the tail panel and overlay the tail lights are old and show some minor cracking. Exhaust tips look okay but had a bit of corrosion on the side where they attach to the pipes.
Engine/Trans/Axle:  426 CID 465 HP Mopar Performance crate motor. John claims that he installed it right out of the crate with out any modifications. Engine is mounted to a stock small-block K-member using Schumacher motor mounts. Stock cast-iron exhaust manifolds are installed for the exhaust. Ignition is a Mopar Performance electronic ignition system. Engine is topped with a single 750CFM Holley vacuum secondary carb with electric choke. On the cooling system I noticed that there is no fan shroud installed when there probably should be one. The trans is a 727 Torqueflite rebuilt by a local performance shop. John says the transmission was rebuild using high performance "red bands" (not sure what they are) and a "stock" torque converter. The rear axle is an 8.75" unit. Center case is a "489" Sure Grip housing with 3:23 gears.
Interior: The interior is a standard black vinyl bucket seat interior with standard gauges, a center console and a Slap-Stick shifter. The seat covers, carpet, door sill covers, headliner and door panels are all new and look nice. The dash is an AC dash with the AC vent openings and has no cracks. The steering column looks old and has some scratches. The center console looks old, has some scratches and the storage compartment door hinge is messed up preventing the door from closing correctly (those things have always been a problem). The woodgrained inserts that go in the door panels (above the arm rests) look old as do the door release handles and window crank handles.
Test drive: The engine fired right up even though it was only about 42 F. The exhaust is relatively loud and "rumblely," On the drive the car was "tight" with no excessive squeaks or rattles. The only noise other than that of the Hemi came from the speedometer. The speedometer needle fluctuated and I suspect the speedometer cable needs to be replaced. The Hemi ran perfectly without a stumble or stutter and the transmission shifted firmly. John didn't press the car and took it easy - I think the fastest we went was about 45 mph (he cringed every time he hears a tiny piece of road debris hitting his paint job!). At one point I asked him to kick the transmission down into 2nd gear. He did so but only briefly and the acceleration was somewhat underwhelming for a 465HP Hemi. However, I believe it was because there are 3:23 gears out back and he didn't keep his foot in it long to allow the RPMs to build up enough for the Hemi to reach it's stride.
John's Challenger is a relatively nice Hemi "clone". The basic car is good and the body and paint (the hard time and cash consuming stuff) are really nice given the extent of the work done. The engine is solid and the transmission appears to be also. The interior is a not as sharp as the outside - the big stuff is good (seats, carpet, headliner, etc) but it needs some attention to the lesser things (steering column, center console, door panel inserts, etc) to make the car really nice. I see Hemi E-body "clones" going for a more money than John is asking. Maybe those cars are exceptional and need nothing, I don't know. John's car is all there, it just needs some detail parts, finishing and "polishing" to make it really nice. He's asking $57,900.
« Last Edit: March 05, 2013 - 09:19:00 PM by RzeroB »
Cheers!
Tom
St Louis, MO
Offline 'Cuda Hunter
  • Tastes Like Chicken
The red interior is beautiful.
V code to boot.  That's a pretty cool car.
Offline RzeroB
I'm going to make an appointment to go look at the '70 six pack Chally sometime soon and give you all a report on it too.
P.S.
C.H.  I see you still haven't pulled that snake out of your nose yet... what are you waiting for? That thing really creeps me out!!  :eek4:
Cheers!
Tom
St Louis, MO
It keeps looping back into the other side.  I'm tryin !   :lol: :lol: :roflsmiley:
Take some pics of the red interior if the owner does not mind.
Offline RzeroB
I received an email today from the owner John. He sent some more details about the work that was done to the car and I am posting them below. He also sent me a bunch of photos and I am including them as a link to a Photobucket albumn. If you contact John, tell him you heard about the car from me (Tom).
FOR SALE
1971 Dodge Challenger R/T Clone, 426 Hemi Crate Motor
It has 465 Horse 485 Torque, the car has new hemi handling, 960 torsion bars, new hemi rear springs, new hemi sway bar, new ball joints, tie rods, idler arm, bushings etc. power steering, new big block radiator from Year One, the transmission has been rebuilt, new torque converter, the 489 posi case has 323 gears has been rebuilt with new bearing, new axle bearings, new drum brakes, new brake lines, and 3/8" fuel line, new ralley wheels with new Good Year tires 235/60/15, the interior has all new panels, new dash, new head liner, the seats are new, new carpet. The body has been rotisserie stripped and cleaned, new OEM-style quarter panels , new trunk pan and extensions, new bumper
Contact John at 636-221-1640 or jmhamer67@hotmail.com
http://s1087.beta.photobucket.com/user/tomravak/library/#/user/tomravak/library/Hemi%20E-Bodies/1971%20Hemi%20Challenger%20clone?&_suid=1362775946244024447571676664836
« Last Edit: March 08, 2013 - 03:53:16 PM by RzeroB »
Cheers!
Tom
St Louis, MO
