Author Topic: Saving floor pans with pin holes  (Read 765 times)
Offline dfark
  • Hold on to your lugnuts, time for an overhaul
« on: February 13, 2013 - 07:58:25 PM »
My floors  and trunk are pretty solid but I am noticing some pinholes here and there.      I have not sandblasted yet that may tell the story.   Should I even consider saving them or just replace them now while I can?    :dunno:
72 Challenger project
05 Dodge Cummins 3500
Offline edl94
  • She Cuda
Re: Saving floor pans with pin holes
« Reply #1 on: February 13, 2013 - 09:51:13 PM »
If there is enough rust to form pin holes they are done. I tried to weld pin holes in mine but they were so thin it would burn a bigger hole the second you started welding.
Offline jimynick
« Reply #2 on: February 13, 2013 - 11:56:52 PM »
:iagree: What the man said. I DID blast mine and you'll be pleasantly amazed at how it will turn into a lace curtain, right before your eyes. Put a 1 piece in if you're serious about the car. Just my  :2cents:
Offline dfark
« Reply #3 on: February 14, 2013 - 07:08:59 AM »
Thanks guys,   that was the answer I expected.   Might as well do it now while she's all stripped down :walkaway:
