Author Topic: 6.1 hemi blower thoughts on the kenne bell  (Read 2830 times)
Offline loiblcustoms1
« on: February 18, 2013 - 02:59:48 PM »
Iam gathering parts for a cuda build and looking at a kenne bell supercharger also needing a stand alone harness and ecm any ideas??  What iam building is a 70 cuda that should be a nice build i have a schwartz chassis on the way a stock 6.1 hemi 545 trans etc... Lots of custom stuff...Just never done a mopar before any ideas would be great thanks Bret
Offline Modern Muscle
  • Moderator
    • Modern Muscle Performance Group
Re: 6.1 hemi blower thoughts on the kenne bell
« Reply #1 on: February 19, 2013 - 09:09:41 AM »
Kenne Bell works great on the 6.1 just keep it around 8lbs of boost as for the engine management this is a good option
http://www.modernmuscleperformance.com/Drive_by_wire_engine_managment_kit_for_Gen_3_Hemi_p/1-dbw-kitauto08.htm
Offline David Weber
  • MAKING OLD NEW AGAIN AND NEW OLD
    • MODERN MUSCLE PERFORMANCE GROUP
« Reply #2 on: February 21, 2013 - 08:31:07 PM »
The 2005 truck box with mods for a 6.1 tmplate works great. Had a customer do a 69 Dart 6.1 with an Edelbrock E-Force. Worked great and was easily tuned with CMR software.
Thank You
David Weber
Modern Muscle 276-666-1934
Offline nqkjw
« Reply #3 on: February 22, 2013 - 02:43:04 AM »
I've got a KenneBell on a 5.9magnum in my 2000 Ram running at 8psi.
No issues and a nice neat low fit.
Burnouts are cool but Traction is the Action
Offline David Weber
« Reply #4 on: February 23, 2013 - 05:55:11 AM »
If you are up for it you should either replace the stock pistons with the drop in replacement piston we make (no balancing required) or pull out your pistons and open up the top ring gap for a boosted application. The 6.1 pistons have a very high ring replacement and it is a weak link. Opening up the ring gap will reduce damage from cylinder pressure spikes form detonation.
Thank You
David Weber
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #5 on: June 26, 2013 - 07:38:25 AM »
I would think that a twin screw type blower  (kenne Bell ) runs hotter than maybe a roots style (Magnunson). That might be better on a street car that sees alot of use  :bigsmile:
Offline GreenFish
« Reply #6 on: July 01, 2013 - 06:11:28 PM »
Go to DIYautotune.com and check out megasquirt.  Depends on your level of confidence technically. Also FAST XFI would work but expensive.
