Author Topic: Shaker Carb Air and Vent Pulls (correct under-dash location?)  (Read 2591 times)
Offline anlauto
Re: Shaker Carb Air and Vent Pulls (correct under-dash location?)
« Reply #15 on: February 22, 2013 - 10:27:18 PM »
This whole time I figured you had a big ol' Hemi or something that's why you said a drill would reach....all the while I was thinking there would be lots of space with a small block or even a 440....
I say have at it...get that hole drilled  :2thumbs:
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #16 on: March 28, 2013 - 04:36:29 PM »
Question about the Shaker "CARB AIR" pull lever.  See attached photos.  I removed the old CARB AIR foil sticker to replace it with a new one.  The pull lever says "VENT".  I looked online at repops, and my CARB AIR pull lever is different than what's being made and sold today.  The total length is correct at 44", but I'm wondering if the previous owner just used a VENT pull from a different body Mopar, and just put the sticker on.  Did the factory put foil stickers on VENT pull cables for use with Shakers and/or Air Grabbers?  Can anyone solve this mystery for me?  I am considering buying a repop just to have a correct looking piece, although the VENT pull functions just fine.  Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline filmsurgeon
« Reply #17 on: March 29, 2013 - 12:10:41 AM »
Based on what I've read in the linked thread below, I believe I have an early repop (using a B-body VENT cable). With that, I think I'll just put on the new CARB AIR foil sticker, and be done (and happy) with it. I'd rather have an early repop that is more similar to the original cable, than a newer repop that has so many differences.  Any feedback still appreciated.  Thanks.
http://board.moparts.org/ubbthreads/showflat.php?Number=6573934
